FS: ECU and Race Wiring Harness - $300
ECU and wiring harness from FrankyIII - $300
The wiring harness was professionally stripped and rewrapped. Let me know if you have any questions.
ECU and wiring
Will this work with all Ls series, and can it be used on a street driven car that has no CATS?
577nitro- Posts : 5
Re: FS: ECU and Race Wiring Harness - $300
speaking for Tim...
Yes, the wiring harness is from an LSx engine. And sure, the wiring and PCM would work on a street driven car just fine. BUT... it will need a specific tune for your engine no matter where/how you drive it.
if im not mistaken, that style ecm should only be used with a 24x/1x trigger setup found on a gen 3 engine.
As mentioned, the wiring has been stripped and has just the bare essentials for racing. The harness has wiring for two oxygen sensors.
sharkey wrote:gen 3 engine.
Ah. Copy! So that's LS1, LS6, LM7, L33... right?
