Fluid for Hydroboost
+3
phlip
7 posters
I'll be using the Turn one pump, Ford Hydroboost, and of course the Porsche rack for my conversion.
According to Alldata the booster and rack are supposed to use ATF. Alldata also says the stock GM pump
is supposed to use GM power steering fluid.
What kind of fluid are people using and what set-up are they using it with.
Thanks in advance, this is a great forum. No BS, just good useable info and interesting tales of other sick people and thier adventures of creating a car that for all intents and purposes you can't just go out
and buy. It's like a frikin support group.
phlip- Posts : 67
Re: Fluid for Hydroboost
Well, I'm new to HB. I used Redline PS fluid http://www.redlineoil.com/product.aspx?pid=79&pcid=27
F-body pump and mustang HB, no PS rack.
+1 for Redline PS fluid.
I am using it in both my 948 and 2500 Suburban Hydroboost systems.....no issues so far.
Turn one recommends the ATF I believe. I have used both without any problems, If you use regular power steering fluid and the pump makes noise try ATF, it seems to run quieter.
I'm using Royal Purple power steering fluid with no issues.
RS Technic- Posts : 73
Thanks for replys. I think I'm going to use Amsoil ATF and see how it works,
since I have plenty of that at the shop already. And it's almost free to me.
phlip- Posts : 67
I asked Turn1 if it was safe to use ATF, they said any name brand synthetic ATF is fine. I was using PS fluid previously with no issues; the rack blew out on my track day over the weekend.. when i replace the rack ill refill with a synthetic ATF.
I dont think the PS fluid was to blame, the rack was original with 130k miles so it was probably bound to happen eventually.
Techno Duck- Posts : 447
Hate to reopen a 3 year old thread but it looks like its half and half of power steering fluid and atf. I just bought the Mustang hydroboost from TPC. What fluid is everyone using?
fantic- Posts : 48
» How close to the motor can I mount the fluid reservoirs?
» Sources for brake fluid resistant hoses
» A fluid reservoir to fit on the stock clutch master cylinder?
