» 5.3 conversion on 88 Turbo
Today at 11:00 am by kevin924kevin
Today at 6:37 am by Patb
» Clutch Issues - HELP!!!
» Hydroboost Lines from TPC
» 1984 Gen IV 5.3 Swap
» Dry Sump Oil Pan Fitment
May 2018
78910111213
14151617181920
21222324252627
28293031
Hydroboost and hollow brake pedal - drill?
Post  chrenan on Sat Mar 11, 2017 7:43 pm
Hi guys. I'm working on the brake pedal attachment to the hydroboost.
Using the TPC provided mounting plate, clevis, Ford hydroboost unit and its connecting to the late style hollow brake pedal pictured below. I test fit everything this afternoon and I'm getting binding as the pedal is depressed, seems like the clevis is angled upward too steeply. I think re-drilling the pedal slightly higher will fix this. Has anyone been down this road before with a hollow brake pedal? Any measurements on where to drill?
Thanks for any tips.
chrenan
Re: Hydroboost and hollow brake pedal - drill?
Post  zeusrotty on Sun Mar 12, 2017 11:47 am
You need to drill it, and the binding is probably more because you tightened the nut on the Clovis to much where it attaches to the pedal. Ask me how I know.
zeusrotty
Post  matty89 on Sun Mar 12, 2017 1:46 pm
i didnt redrill my i ajusted the pedal :S its really a sensitive pedal i would say Smile
matty89
Post  chrenan on Mon Mar 13, 2017 10:53 am
OK, re-drilled the pedal slightly higher up, got a nice smooth action from the top of the travel all the way to the carpet. Re-attaching the return spring on the top of the pedal was not my favourite part of the job. What a pain. Everything is bolted up now, on to the next steps!
chrenan
Post  majormojo on Mon Mar 13, 2017 9:02 pm
How do you feel about the strength of the pedal/clevis joint without the bushing like the original? I was skeptical after reading some comments here about the need for that bushing and so I picked up an early solid pedal to drill instead. That said, I have not done so yet, so I can still go either way. I seem to recall that for my setup I needed to move the hole up about 3/4 in, is that about where you ended up?
majormojo
Post  chrenan on Tue Mar 14, 2017 9:03 am
majormojo wrote:How do you feel about the strength of the pedal/clevis joint without the bushing like the original?
I definitely gave it some thought. Less so after having the pedal out of the car, despite being hollow it is not flimsy. I've driven vehicles with hydroboost brakes before, and they all require very little pedal effort, they feel over-boosted, so I'm not too worried that the pedal will fatigue through use.
majormojo wrote:I seem to recall that for my setup I needed to move the hole up about 3/4 in, is that about where you ended up?
I'd say that's about where I ended up. Basically just above the existing hole, but with enough meat between the holes to be comfortable. I held everything in place by hand and moved the pedal up and down to find smooth in and out action, then marked it and drilled on the press. I'm usually good about taking pictures but after two afternoons stuck under the pedals pictures were the last thing on my mind.
chrenan
Post  majormojo on Mon Apr 03, 2017 12:45 pm
I've been working on the car again and I drilled and installed the early pedal this weekend. Only thing I'm stuck on is the pedal return spring. I might have lost it and I don't recall where it connects. I did find a spring in some misc parts bin that could be correct... Anyone have a picture or diagram of how to install? The Porsche parts diagram I've seen only shows exploded view.
majormojo
Post  chrenan on Mon Apr 03, 2017 3:43 pm
You can feel where it connects to the car with your fingers, and if you are at the correct angle can actually see where it connects as well, but it's tricky and would be tough to take a picture.
This is the spring:
chrenan
Post  majormojo on Mon Apr 03, 2017 4:41 pm
Super, thanks. I don't think that is the spring that I found. Current me is really cursing the old me that did such a sloppy job of documenting and tracking things several years ago... Twisted Evil
majormojo
