Strange Clutch Pedal Engagement
I have the stock 944 clutch master cyl. and c5 throw out bearing. When I stab the clutch pedal I have a solid pedal all the way to the floor and the clutch disengages. When I slowly push it in there is no resistance and falls to the floor. Bad Master? I've bled two cans of fluid through it every way I know.
fantic- Posts : 48
Re: Strange Clutch Pedal Engagement
if you push the pedal down fast and hold it down does the clutch stay disengaged, or does it slowly bleed off?
i would suspect the master cylinder is leaking fluid past the piston.
I was planing on taking it out for the first time today. Going through the pre flight checks and noticed this. Let you know. Thinking the master.
fantic- Posts : 48
porsche master or gm master ? and its a gm slave ?
matty89- Posts : 62
Stock Porsche master C5 slave. I just drove it for the first time. I can hold it in for over 30 sec in gear and then feather the clutch out after I push it down fast. I cruised around my 1200' circle drive a couple of times slow and in first and went to shift into second and the pedal was at the floor. I adjusted the helper spring on the pedal all the way out. No difference.
fantic- Posts : 48
