No fan signal from PCM
I'm not receiving a fan signal from my PCM. I have a PSI harness and the computer is unknown. I bought it that way. I checked the temp on the OBD2 and it went up to 240 deg and still no signal. I know the fans and the relays work. Before I send my PCM off is there anything I can do to check it out?
fantic- Posts : 48
Re: No fan signal from PCM
what type of pcm is it? and any clue what it may have come from?
gen 3 truck engines used a mechanical fan, so the fan turn on wasnt active on them.
sharkey- Posts : 713
All I know about the PCM is that the SERV# is 9354896. Someone in ink wrote "HPT 5.3" on a label. Every thing else works. No codes. I don't have anyone local so I'm about to send it off to get it checked out. Just looking for an easy fix before I do it.
fantic- Posts : 48
Sharkey is correct about the harness if it came from a Truck. Mine was the same deal, but I was able to flash it with HP Tuner to get them to enable E-Fans.
I would assume that HPT is referring to HP Tuners, so they might be able to help you out, or the previous owner.
Depending on the package they bought, he could carry over the license to you to use. I was fortunate to have my PO do that on mine.
944_GASM- Posts : 68
Thanks for the replies. The PO now lives 2 states away so probably not an option. I can use the Porsche fan setup for now and see how it drives. Once I get it sorted out send it to someone to program it.
fantic- Posts : 48
i used stock porsche harness and fans for my setup works great
matty89- Posts : 62
matty89 wrote:i used stock porsche harness and fans for my setup works great
+1
Sharkey was right. It came out of a truck. I got it back yesterday and hooked it up and everything works. Kind of surprised that the fans alternate on low speed. I was chasing a high idle at the same time. Now it settles in at around 750.
fantic- Posts : 48
Today at 9:56 am by ndog52
