3/4" Xmember and swaybar drop kit
I have another spare set of these in billet aluminum.
Longer M12 Xmember bolts included...
$75 shipped US-48
$75 shipped US-48
Re: 3/4" Xmember and swaybar drop kit
Is there an advantage to the 3/4" vs 1/2" ?
Does either require extension of the steering shaft? I have a manual rack.
Thanks.
Thanks.
944_GASM- Posts : 68
3\4" has more bumpsteer and is not much noticable on a daily driver.
You should lengthen steering shaft by 1\2".
this may be a dumb question, but why would you want more bumpsteer?
HGT1- Posts : 9
you dont want more bumpsteer. spacing down the crossmember is not something we want to do, its something that has to be done to fit engines in that were never designed to be there.
I haven't reached that point yet, but will the 1/2" spacers be that tight that another 1/4" is needed? I've heard of issues with the power steering lines hitting the oil pan, but I'm running a manual rack. The only area I see major issues, is with the DBW TB, since I believe it's a little larger than the DBC.
