Steering Rack Question
I recently disassembled my steering rack to clean and do an entire rebuild. It is a 1983 944 N/A steering rack. I am curious about what bolt or plug goes in to the open bolt hole to the right pictured below. Any help in pointing me to the right bolt would be much appreciated. It is threaded just not sure what it is I need to order to fit. Thanks
Jchard944- Posts : 96
Re: Steering Rack Question
That's the steering rack centering hole used to center the rack during alignments I think. This tool goes in there:
You can make the tool from an M10 x 1.0 thread bolt, or you could cut a bolt off short to make a plug.
chrenan- Posts : 203
Awesome thanks for the response that's exactly what I was looking for.
Next question, does anyone know where I can pick up an extra bushing that goes in the bottom of the steering Rack pictured below. When I took this Rack off the car the bottom of that shaft was exposed and that bearing was tore up. I took the bearing out but cannot locate another one. Also once the bearing is installed how do you seal up the bottom so dirt and grime cannot access the bearing or bottom of steering shaft?
Found the part piece I was looking for. For those who are looking for this bearing the future it is:
INA BK1012 Needle Roller Bearing, Steel Cage, Closed End, Open, Metric, 10mm ID, 14mm OD, 12mm Width, 23000 rpm Maximum Rotational Speed, 1530lbf Static Load Capacity, 1240lbf Dynamic Load Capacity.
It can be purchased on Amazon actually for just over $5/each
» Question on steering rack dimension
» WTB: manual steering rack
