» Transaxle rebuild
Yesterday at 9:51 pm by Arthropraxis
Yesterday at 8:58 am by JSP
Yesterday at 12:44 am by Porsche951toLS3
» Tpc LS adapter plate
» Headers, headers, HEADERS!
3yr old rebuilt motor first start
Post  fantic on Sat Jan 28, 2017 6:59 pm
I have a motor that was rebuilt approximately 3 or 4 years ago. I'm new to the LS. On the old small blocks I would spin the oil pump with a tool in the distributor hole. Not sure how to prime the LS motor before the first start.
fantic
Re: 3yr old rebuilt motor first start
Post  sharkey on Sat Jan 28, 2017 7:09 pm
aside from cranking it on the starter, the only way to prime it is to use a pressure pot or a pump to pump the oil in through an oil galley plug. you can use the oil pressure sensor port.
Post  fantic on Sat Jan 28, 2017 8:02 pm
Thanks. I had the valve covers and the intake off and there is still assembly lube on every thing. Should be good. Just wanted to be safe.
fantic
Post  Rich L. on Sun Jan 29, 2017 1:08 pm
Mine only sat for 6 months before first start. What I did was pull the spark plugs, disconnect the coils and spin it with the starter until I had oil pressure. The hooked it all up real quick and it fired right up. Good luck.
Post  racertomtom on Sun Jan 29, 2017 6:44 pm
Rich L. wrote: What I did was pull the spark plugs, disconnect the coils and spin it with the starter until I had oil pressure.
That's what I'd do, even if I had a way to pressure fill it.
racertomtom
