March 2019
C5 Brake Caliper Adaptors
Post  Jchard944 on Mon Nov 28, 2016 2:59 pm
When researching a while back I could have sworn I came across someone building an adaptor for C5 Brake Calipers may have been dreaming. Regardless with my setup I will be using the C5 Brake Calipers in the rear as I am using the complete rear subframe from a C5 Z06. I also have a set of C5 front calipers as well and I wanted to use them up front if possible.
I was going to have the company building my car see if they could make an adaptors to fit on the 83 front end but I wanted to reach out here first to see if there was any drawings, pictures, etc.
Jchard944
Re: C5 Brake Caliper Adaptors
Post  erioshi on Wed Nov 30, 2016 5:47 am
Any chance you have also been doing research on the norotors.com forums? Second and third generation RX-7s frequently use Corvette calipers as upgrades, and seem to recall drawings being available for adapters. Interestingly 2nd generation RX-7s can use an adapter to fit C5 calipers combined with Ford Mustang rotors on their OEM hubs for a significant brake upgrade. I have a friend who was doing an RX-7 LSx swap.
erioshi
erioshi
Post  Jchard944 on Wed Nov 30, 2016 6:22 am
Have never been on their forum but I will check it out and see what they look like. May help get me a little close to figuring out how to get these on the front of the car. Thanks for the heads up.
Jchard944
Post  944-LT1 on Wed Nov 30, 2016 4:57 pm
Post  Jchard944 on Wed Nov 30, 2016 8:06 pm
Ahhhhhh I knew I wasn't going crazy. I will be using C5 Z06 Brakes from an 04 Z06. This helps a lot though with some of the trouble I will have to account for.
Thanks for sending it over.
Jchard944
