» Magnuson supercharged car?
» WTB: LS powered 968
» Poly engine mounts melted
» Intake choice
» JP's LS1 Conversion
low clutch pedal grab
Post  matt889 on Thu Nov 17, 2016 10:12 pm
i got the clutch / pressure plate / flywheel from tpc and the slave with adaptor plate also
im using a new stock porsche clutch master
it only grabs 2 inchs from the floor .... i have resistance from the top down but only grabs to unclutch really close to the floor i ajusted the dead pedal and doesnt change anything ?
matt889
Re: low clutch pedal grab
Post  dsrracer on Fri Nov 18, 2016 6:33 am
I have the same situation. Some earlier threads indicate the MC capacity is marginal and the fix is to replace it with a 7/8 bore Wilwood 260-10374. I don't think it's a bolt in, so I'm planning to drive and get some miles before I replace it. Maybe someone has found a more direct replacement since those were written.
dsrracer
Post  matt889 on Fri Nov 18, 2016 10:16 pm
dsrracer wrote:I have the same situation. Some earlier threads indicate the MC capacity is marginal and the fix is to replace it with a 7/8 bore Wilwood 260-10374. I don't think it's a bolt in, so I'm planning to drive and get some miles before I replace it. Maybe someone has found a more direct replacement since those were written.
damn ...i just bought the new oem one loll figures ...
matt889
Post  matty89 on Thu Mar 30, 2017 7:32 pm
anyone else with a Input ?? parts they used ?
matty89
Post  fantic on Fri Mar 31, 2017 7:27 am
I had basically the same problem. I wasn't getting any pedal till half way down and then engage a couple of inches from the floor. When I ordered the Hydroboost from TPC I went ahead and bought a new clutch master from them. Bolts right up. Full stroke. Disengagement is about half way down. I believe it was a 3/4 Master.
fantic
Post  matty89 on Tue Apr 04, 2017 9:04 pm
fantic wrote:I had basically the same problem. I wasn't getting any pedal till half way down and then engage a couple of inches from the floor. When I ordered the Hydroboost from TPC I went ahead and bought a new clutch master from them. Bolts right up. Full stroke. Disengagement is about half way down. I believe it was a 3/4 Master.
was trying to save my stocker one .... its new
matty89
