» Dual MC Mounting Bracket
Yesterday at 10:02 pm by 948
» LS1 1st start
» Need help! Car won’t start
» Brand new ls3 build
» Lighten clutch pedal feel?
January 2019
78910111213
14151617181920
21222324252627
28293031
LS3 & LS1 parts - new heads/intake/camshaft/injectors & much more
Post  Sterling Doc on Tue Nov 15, 2016 10:30 pm
All of the LS3 parts came off of an LS3 crate motor before it was fired for the first time with exception of the injectors, which were used for about 4 hours of run time before being taken out.
Complete take-off LS3 heads: $600
LS3 intake: $250
LS3 Fuel rail: $50
LS3 camshaft: $150
LS3 injectors: $150
LS3 Oil Pan/windage tray, and oil pickup: $100
LS3 timing chain, and sprocket: $100
LS3 oil pump
PRW high performance water pump (this is specifically for high-RPM applications): $200 This was run for one racing season.
LS1 injectors, 28lbs/hour: $50
2 LS1 computers: $100
LS1 camshaft $75
AIM throttle position sensor and patch cables: $75
Various air filters- 3.5, and 4" inlets, 2 new, 1 only used for fitting (small filter)
$30 for the large new one.  $20 for the small 3.5" one.
MAF's 3.5" new - $50, 4" used $35
Manthey Racing 7.850" pushrods for LS motor - very short amount of use, restricted oil holes to limits oil pooling in heads. 1/16 over stock diameter for increased stiffness. Custom, and not cheap. $100. New OEM LS3 pushrods $50
LS to 944 conversion clutch disk, stage II, little use. Clutch disk only. $50.
Sterling Doc
Re: LS3 & LS1 parts - new heads/intake/camshaft/injectors & much more
Post  Jchard944 on Wed Nov 16, 2016 2:29 pm
I have a friend who needs those heads. Please PM me with your contact information. He can pay through pay pal or however you like. Once you PM me I will send you his contact information so you can call him. He said he needs them like yesterday.
Jchard944
Post  Sterling Doc on Thu Nov 17, 2016 10:10 am
PM sent.
Sterling Doc
Post  misterfx8 on Fri Nov 18, 2016 8:44 pm
how much shipped for the clutch disk to 02911? thanks
misterfx8
Post  Sterling Doc on Fri Nov 18, 2016 10:12 pm
misterfx8 wrote:how much shipped for the clutch disk to 02911? thanks
PM sent
Sterling Doc
Post  misterfx8 on Fri Nov 18, 2016 10:39 pm
I dont have enough posts to pm. whats your paypal address?
misterfx8
Post  Sterling Doc on Sun Nov 20, 2016 8:16 pm
misterfx8 wrote:I dont have enough posts to pm. whats your paypal address?
$85 to linda dot kuhns at hotmail dot com (wife controls the Paypal funds...)
My email is eric dot kuhns at gmail dot com - let me know when you send it out, and I'll get the clutch disk out to you.
Sterling Doc
Post  misterfx8 on Mon Nov 21, 2016 8:31 am
sent you an email.
misterfx8
Post  misterfx8 on Mon Nov 21, 2016 8:33 am
what year and model are the ls1 computers?
misterfx8
Post  Sterling Doc on Mon Nov 21, 2016 2:27 pm
misterfx8 wrote:what year and model are the ls1 computers?
I have a tentative offer on the computers. Clutch disk is available.
Sterling Doc
Post  misterfx8 on Tue Nov 22, 2016 7:32 am
Payment sent for clutch disk.
misterfx8
Post  Chaxce on Sat Nov 26, 2016 3:43 am
Any chance you still have one of those LS1 computers? If so what are they manual transmission and what year car did they come from?
Chaxce
Post  Sterling Doc on Sun Feb 05, 2017 10:38 pm
Sorry about the very late reply, haven't been around!
I do still have the computers, and they are for a manual trans.
Most of the rest is gone.
I have the oil pan from the crate motor, LS1 injectors, and LS1 cam, and a few odds and ends.
I'll make it a point to look in more often!
Sterling Doc
