Always throwing code P0502
+2
yamamtx
6 posters
Hello Guys I am still struggling with the vss and was wondering do I have something hooked up wrong or is it in the tuning as I get a "P0502-vehicle speed sensor A circuit low" every time I drive it.
yamamtx- Posts : 97
Re: Always throwing code P0502
do you have the tpc speed sensor kit installed on your axle? is it wired into the correct pins on the pcm?
I believe it is a TPC VSS kit. I actually bought most of my parts off of a guy that gave up on his project. I ran one of the wires to the computer and the other I ran to a ground. Does that seem right? Do you know which pins it should run to? Ill check on what I did.
yamamtx- Posts : 97
Just ran out and checked looks like one is going to the green/black wire Pin 20 and the other is going to purple/white wire Pin 21
yamamtx- Posts : 97
just make sure the VSS pinout is correct.
VSS Lo, pin#20, VSS pin A
VSS Hi, pin#21, VSS pin B
both should be on the "RED" connector
Punisher948- Posts : 39
So is it possible to get the wires crossed from the vss kit? My vss kit had two black wires coming from it with no other markings.
yamamtx- Posts : 97
vss kit has a yellow and black wire on it if im not mistaken
matt889- Posts : 214
If you turn the connector over and on the release you will see the Pinout letters for that connector. They are very small so look closely. Once you confirm the correct Pinout and the problem remains you can at least be assured this is not the problem.
Brian
PS post your PCM info and I'll see if I can get the schematic and post so we all can help...
Brian
Punisher948 I will try to find the info you are looking for and post it. What PCM info are looking for?
Matt889 my vss sensor only has two black wires coming out of it.
Can I just shut the engine light off for code 502 on Hptuners without hurting anything? Getting sick of clearing the code, just worried I might hurt something. At least until I get this figured out.
yamamtx- Posts : 97
Yamamtx
This has happened to me before. Mine would throw a light as soon as the car moved. The road ripped off my ABS wires on the front of my DD, at some point I fixed the wires but got them backwards. This is the reason I had the reoccurring code. I reversed the wires and that fixed the problem.
I just wanted to the PCM info (make, model, year, and engine of the tune you’re using) this was to verify if I could, the correct Pinout. In my previous post ,on this topic, I got my info from a general 99-02 Pinout.
I believe your pinouts matched my pinout info also. I have a 2002 Ls 4.8 with a stock tune and computer. I believe your info was correct as it matched lt1swap.com
yamamtx- Posts : 97
I tried swapping the wires around today and I am still getting the same code. The only thing I can figure is maybe I have the Vss portion set up wrong on HPTuners? I spent hours looking how to set it up but still not sure if it is right. Anyone know how to set it up for sure?
yamamtx- Posts : 97
Have you tested the sensor to make sure it is functioning correctly?
erioshi- Posts : 227
I have not tested the sensor, do you have a good procedure to test it? Thanks
yamamtx- Posts : 97
i have mine pluged in and it works but isnt giving the right speeds im maxed at 24 mph .. when im going freeway speeds ..... weird i will recheck the gap of the sensor vs the wheel on the axel.
matty89- Posts : 62
