Brake bias issue between L and R front wheels
So for some reason my right front brake wants to lock up before my left front. I'm running the BMW hydroboost with 944 master and brake bias regulator for the rear. All parts in the system are new, including the LS430 calipers. Any thoughts?
jpkinerk- Posts : 174
Re: Brake bias issue between L and R front wheels
Dragging pistons in the caliper that lock up first?
Hmm, I'm not sure. How would I indentify that issue exactly?
Inspect the caliper piston seals. First thing to do is get the front wheels off the ground and spin the the wheel by hand see if the offending caliper is dragging. If it is the piston seals probably need to be replaced. Here is a link to get the seals https://www.zeckhausen.com/catalog/index.php?cPath=88_975_976_980 should you need them.
Thanks for the tip. Threw the car up on the lift and checked each front wheel. They both seem to be spinning freely. I did notice something else odd though. I took off each wheel to inspect the calipers more closely, and noticed my L caliper is off center on the rotor. The R caliper is evenly centered on the rotor. To clarify what I mean by "centered," i'm referring to there being equal distance between the rotor surface and pistons on the inboard and outboard side of the caliper pistons.
Any idea if this could be causing my problem? I didn't have my phone on me, but I'll get a pick tomorrow.
Could be. Take the pads out on the off center side and see if they are wearing evenly. At any rate the calipers should not be off center. Make sure you don't have a kinked brake line on that side, that could cause an issue too.
Good idea. I hadn't thought to trace the entire line just to be sure there's no kinks or anything else suspicious. Appreciate the input. I'll keep looking!
» Porsche Brake bias used on hydroboost installs or no?
» 83 944 Front Brake Calipers Left and Right different?
» Late 944 330mm Front Brake Option
