944 Rim options?
+2
Jasonscottw
yamamtx
6 posters
944 Rim options?
Hello Guys,
I am looking for some Rims and I have been struggling to find stuff. 1983 944
I don't want them to cost more than the car is worth!
I would like black, 17 or 18 if possible.
As wide as I can stuff in there with out loosing performance.
Keep weight respectable.
etc.
Please help with ideas. Thanks
etc.
yamamtx- Posts : 97
Re: 944 Rim options?
Lots of 17" Boxster wheels on EBAY for cheap. Not sure about an '83, but on my '87, 17's w/pilot sport 255's rear and 205's front fit and perform great. After powder coating them black they look great too-
Jasonscottw- Posts : 125
keep in mind with wheels off a late model car wont fit on an early 944 (83-86) without fairly wide spacers.
I would rather not use large wheel spacers if I don't have to. There has got to be some rim options out there!
If I can't find rims to fit does anyone know the best hubcentric wheel adapters that are a high quality product?
yamamtx- Posts : 97
I got a set of Borbet replica cup wheels 17x7.5 and 17x9 for a sweet deal off craigslist. They are early offset, and look great on my 86 n/a.
I've been trying to look for another set for track wheels, so I'll be really interested to hear about good deals on early offset wheels.
jHo- Posts : 42
87s LS1 with black 17" boxster rims. no spacers
gdopnt- Posts : 127
I like those, I wonder how they would fit on a 1983?
yamamtx- Posts : 97
they would require spacers on an 83. 87+ 944 cars had a wider suspension width, that resulted in a higher offset wheel being needed.
A wide body wheel like a 40mm offset 10x18 fits without spacers on the rear. With a .09" rotor spacer you can use 330mm rear rotors with the narrow offset hubs and keep the park brake. I don't think there's a wide body front wheel you can use without a spacer unless you use a rear on the front.
I'll be running wide offset suspension on the front.
Last edited by racertomtom on Mon Oct 24, 2016 10:42 pm; edited 1 time in total (Reason for editing : wrong)
racertomtom- Posts : 144
