Hydroboost w/stock master question
Hey guys, I noticed that the stock brake reservoir has a nipple coming off of it as if it were supposed to be used for the clutch master reservoir also. Can I do that? Instead of having a shoe rate reservoir, can I just run a line to that? I have a motive power bleeder so I think it would probably make things easier. Any objections?
zeusrotty- Posts : 444
Re: Hydroboost w/stock master question
thats how they were run from factory
Yes, use that nipple for your clutch master feed hose. It greatly simplifies clutch bleeding for you with your Motive bleeder.
Make sure you use a hose that is compatible with brake fluid, fuel line is not......
hutchjc1- Posts : 68
Thanks guys! That is very helpful. If I can get rid of one more piece and just bleed it with my motive bleeder that makes life way easier.
» HELP!!! Replaced hydroboost and master and now I have a soft pedal.
» Hydroboost Master Cylinder Options
» Hydroboost mounting master does not clear hood
