March 2019
Brake Lines
Brake Lines
Post  yamamtx on Wed Oct 05, 2016 7:37 pm
Hello Guys,
I am trying to reuse my stock brake lines, I cut the ends off and did double flares on the stock lines and hooked it to the willwood master. I have tried over and over again to fix the leaks and I can not get it to stop! What am I missing? Has anyone had luck doing a double flare on the stock lines? Thanks
yamamtx
Re: Brake Lines
Post  sharkey on Wed Oct 05, 2016 11:40 pm
what wilwood master cylinder are you using? i flared mine without an issue.
Re: Brake Lines
Post  gdopnt on Wed Oct 05, 2016 11:45 pm
double or bubble flares? its been a while but I thought it was bubble flares. maybe I'm wrong.
gdopnt
Re: Brake Lines
Post  sharkey on Thu Oct 06, 2016 12:07 am
the stock flares are bubble flares. the wilwood master cylinders typically use a double flare.
Re: Brake Lines
Post  yamamtx on Wed Oct 12, 2016 7:49 pm
I am using a Wilwood 1 inch tandem manual master cylinder. I am going to try a different flaring tool next.
yamamtx
Re: Brake Lines
