» NDog52's 1986 NA 5.3 Build - A Summary
How to wire the VSS into the GM PCM EmptyToday at 11:30 am by Gutterboy
How to wire the VSS into the GM PCM EmptyYesterday at 6:12 am by Colibri Green
How to wire the VSS into the GM PCM EmptyTue Mar 26, 2024 3:29 pm by Blaizefed
How to wire the VSS into the GM PCM EmptyTue Mar 26, 2024 1:30 pm by Raymond-P
How to wire the VSS into the GM PCM EmptyTue Mar 26, 2024 8:49 am by 948
How to wire the VSS into the GM PCM EmptyWed Mar 20, 2024 11:52 pm by Raymond-P
How to wire the VSS into the GM PCM EmptyWed Mar 20, 2024 1:17 pm by Rob44
How to wire the VSS into the GM PCM EmptyTue Mar 12, 2024 3:22 pm by dcoutofstep
How to wire the VSS into the GM PCM EmptyTue Mar 12, 2024 2:10 pm by dcoutofstep
How to wire the VSS into the GM PCM EmptyTue Mar 12, 2024 12:12 pm by ndog52
+2
Hotrodz of Dallas
Jasonscottw
6 posters
How to wire the VSS into the GM PCM Empty How to wire the VSS into the GM PCM
Post  Jasonscottw Fri Sep 02, 2016 12:03 am
So I have TPC's VSS kit installed, but I'm perplexed as to how to wire it into the PCM- which pin/port, and if there is a plug that I need to wire into those pins to mate up with the plug on the kit- thanks
Jasonscottw
Jasonscottw
How to wire the VSS into the GM PCM Empty Re: How to wire the VSS into the GM PCM
Post  Hotrodz of Dallas Fri Sep 02, 2016 7:12 am
Jasonscottw wrote:So I have TPC's VSS kit installed, but I'm perplexed as to how to wire it into the PCM- which pin/port, and if there is a plug that I need to wire into those pins to mate up with the plug on the kit- thanks
What ecu and engine wire harness do you have? I can look and see what wires you need to attach to.
Hotrodz of Dallas
Hotrodz of Dallas
Post  Punisher948 Fri Sep 02, 2016 8:35 pm
Dear Jasonscottw,
Here is the Pinout for the VSS.
99 Camaro 5.7 Engine
Function-----Pin-----Circuit No.     PCM Termination
VSS LO-------A------822------------C2-20
VSS HI-------B-------821-----------C2-21
99 Corvette 5.7 Engine
VSS LO-------A------401------------C2-20
VSS HI-------B-------400-----------C2-21
99 GMC Sierra 1500 5.3 Engine
Punisher948
Post  Jasonscottw Sat Sep 03, 2016 12:09 am
Thank you!
Hotrodz, that would be awesome if you could confirm that info:
The computer:
Serv. No. 12586243
Hdw. No. 12583659
In researching the computer numbers I gather it may be from a later year express van, or a CTS??
Originally I thought it was from a 99 truck, but . . .
I hired a guy to do the final wiring cuz I had to go overseas for a bit- he didn't work out (at all) so now I'm trying to sort out his work, and also my work from a couple years ago Wink
And, any idea which wire coming off the VSS is high/lo?
Really appreciate the help-
Jasonscottw
Jasonscottw
Post  spence Sat Sep 03, 2016 5:11 am
http://www.lt1swap.com/2004gto_pcm_pinouts.htm
That pinout might help you figure things out...
"2004: Serv. No. 12586243 with Hwd. No. 12583659 - Mostly GTO and Express vans got this PCM, as well as Caddy CTS-V. MIGHT be in trucks"
Post  Jasonscottw Mon Sep 05, 2016 9:02 pm
Thanks! Looks like I have a mismatched PCM/HARNESS . . .
Question:
The VSS harness/plug has two wires, but I have three options on the PCM:
-VSS low (pin 20)
-VSS hi (pin 21)
and
-VSS output (pin 50)
What do I do? And yes, I advanced searched this forum and the big 3 LS forums, and the only suggestion I found was to ignore the VSS hi, which doesn't make sense-
Also I'm unsure of what the VSS output would even do/function?
Thanks . . .
Jasonscottw
Jasonscottw
Post  sharkey Mon Sep 05, 2016 10:44 pm
never used the kit, but looking at a pic of one it has a yellow and black wire on the sensor. yellow would be high, black would be low. the vss output on the pcm is exactly that, a vehicle speed sensor output signal, it could be used to run an electronic speedo in some applications.
Post  Rich L. Tue Sep 06, 2016 2:46 pm
The VSS output goes to the dash of the Camaro/Vette. The hi/lo go to the sensor but I don't know if polarity on the sensor matters.
Post  Jasonscottw Tue Sep 06, 2016 10:19 pm
Thanks all- now I just gotta re-pin 20 and 21.
For some reason the PCM is devoid of inputs at those locations-
Jasonscottw
Jasonscottw
