March 2019
Hydroboost w/stock master question
Post  zeusrotty on Mon Aug 29, 2016 10:54 pm
Hey guys, I noticed that the stock brake reservoir has a nipple coming off of it as if it were supposed to be used for the clutch master reservoir also. Can I do that? Instead of having a shoe rate reservoir, can I just run a line to that? I have a motive power bleeder so I think it would probably make things easier. Any objections?
zeusrotty
Re: Hydroboost w/stock master question
Post  sharkey on Mon Aug 29, 2016 11:09 pm
thats how they were run from factory
Post  Hotrodz of Dallas on Tue Aug 30, 2016 8:21 am
Yes, use that nipple for your clutch master feed hose. It greatly simplifies clutch bleeding for you with your Motive bleeder.
Hotrodz of Dallas
Hotrodz of Dallas
Post  hutchjc1 on Mon Sep 26, 2016 3:11 pm
Make sure you use a hose that is compatible with brake fluid, fuel line is not......
hutchjc1
Post  zeusrotty on Wed Sep 28, 2016 12:44 pm
Thanks guys! That is very helpful. If I can get rid of one more piece and just bleed it with my motive bleeder that makes life way easier.
zeusrotty
