Master Cylinder Help- SBC Conversion EmptyYesterday at 11:51 am by geegeesbits@gmail.com
Master Cylinder Help- SBC Conversion EmptyMon Jan 27, 2020 2:27 pm by Porsche951toLS3
Master Cylinder Help- SBC Conversion EmptySun Jan 26, 2020 4:51 pm by j7wolfe
Master Cylinder Help- SBC Conversion EmptySat Jan 25, 2020 6:42 pm by kevin924kevin
» Pedal Assembly - Which one?
Master Cylinder Help- SBC Conversion EmptyTue Jan 21, 2020 5:27 pm by Hotrodz of Dallas
Master Cylinder Help- SBC Conversion EmptySat Jan 18, 2020 7:15 am by Rothaus
Master Cylinder Help- SBC Conversion EmptyThu Jan 16, 2020 6:51 am by 87944turbo
» 82 924 with AUX Audi V8.
Master Cylinder Help- SBC Conversion EmptyThu Jan 16, 2020 2:11 am by Golten1986
Master Cylinder Help- SBC Conversion EmptyTue Jan 14, 2020 2:48 pm by Gumby
Master Cylinder Help- SBC Conversion EmptyTue Jan 14, 2020 6:43 am by 87944turbo
January 2020
6789101112
13141516171819
20212223242526
2728293031
Master Cylinder Help- SBC Conversion Empty Master Cylinder Help- SBC Conversion
Post  mred2nice on Mon Aug 22, 2016 12:04 am
Good Day Everyone
I am not really sure what to do here. I have posted several other times for assistance but I am really not sure what to do here.
I am working with am early SBC conversion using the 2piece C5 belhhousing/adapter package and motor mounts from TexasPerformance. The driver side valvecover will not go on. I am not sure even if sectioning it would allow for fitment. Perhaps the MC is not the right one? Can you all look at it and let me know if it is the correct one and what I can do to alleviate mt problem.
Thanks for helping,
Ed
mred2nice
Master Cylinder Help- SBC Conversion Empty Re: Master Cylinder Help- SBC Conversion
Post  sharkey on Mon Aug 22, 2016 12:36 am
the pictures you have posted havent been good enough to really comment on. if you can get some better pics some people may have some better feedback.
the master cylinder is always very close to the valve cover with these swaps. short (stock height) valve covers are tight. i know with the rocker girdle you need a fairly tall cover, i dont know if its going to be physically possible to make it all work. you may have to consider removing the girdle and going with a shorter valve cover.
Post  spence on Mon Aug 22, 2016 2:58 am
Slot the holes in the adapter plate and move it over till it clears and make a new clevis to attach the brake pedal to make up for the offset to keep everything inline. Or maybe you could use cross member spacers.
The space you have is normal. I'm using hydroboost and I had to rotate it up just a bit so it would clear.
Post  mred2nice on Mon Aug 22, 2016 10:06 pm
Ok...gotcha. Thanks for the feedback.
Can I get your feedback on this pic. Does this look ok or should I replace it? The hose looks suspect.
Ed
mred2nice
