A fluid reservoir to fit on the stock clutch master cylinder?
Does anyone know of a fluid reservoir that will fit on the stock Porsche clutch master cylinder so I don't need to have the hose to the brake reservoir? In the situation I have, the line is a real problem and I would love to eliminate it. I would also be very interested in some low profile reservoirs for the brake master as well.
I am guessing it is just a matter of figuring out the required size outlet on the reservoir and picking one out. Does anyone know the size of the nipple required for any of these?
Open to ideas
Open to ideas
matthewb- Posts : 53
Re: A fluid reservoir to fit on the stock clutch master cylinder?
The remote clutch M/C resevoir from the 04 GTO engine I used in my conversion is compact and mounts easily to the area to the right of the clutch M/C. I gave mine to Skywalker, fits nicely.
I know you want to put the reservoir right on top of the clutch master and I can't really help you there however you may want to try what I did. I got a clutch reservoir from a Honda Accord at the bone yard for $5. I mounted it directly behind the clutch master, in the open area in front of the windshield right next to the fuse box. There is a hole in the firewall right there with a rubber plug it in. Take the rubber plug out and run the rubber hose from the reservoir through the hole and to the clutch master. Its out of the way and the hood closes just fine.
rooster- Posts : 90
Early or late 944 and do you have pics sounds clean install
rooster wrote:I know you want to put the reservoir right on top of the clutch master and I can't really help you there however you may want to try what I did. I got a clutch reservoir from a Honda Accord at the bone yard for $5. I mounted it directly behind the clutch master, in the open area in front of the windshield right next to the fuse box. There is a hole in the firewall right there with a rubber plug it in. Take the rubber plug out and run the rubber hose from the reservoir through the hole and to the clutch master. Its out of the way and the hood closes just fine.
matt889- Posts : 214
