Today at 12:30 pm by sharkey
Today at 8:54 am by Rich L.
Yesterday at 5:04 pm by AMFCSL
» Transaxle rebuild
» Hello, Gentlemen.
» alignment specs
Intake Problem
Intake Problem
Post  dsrracer on Tue Aug 16, 2016 9:20 am
I have an LS1 F-Body with an LS6 intake. Using the TPC kit which installed nicely onto the TT and the cross member but I don't seem to have the same clearance at the front to the latch / radiator as I see in other pictures. I can fabricate an intake as a work around but I'm wondering why? Anyone else with such little clearance? Any issues I should look for? Thanks for any ideas.
dsrracer
Re: Intake Problem
Post  hutchjc1 on Tue Aug 16, 2016 10:00 am
I have / had about the same amount of clearance, I ended up removing the latch mechanism and using hood pins, it allowed a strait run out of the throttle body and also moved the air intake forward of the engine bay to allow a cold air intake point. I can email pictures if it helps but for some reason I haven't been able to post pics.
hutchjc1
Re: Intake Problem
Post  dsrracer on Tue Aug 16, 2016 10:31 am
Pictures would be great! Its a relief that I don't have some more fundamental issue that no one else had. The fact that both the TT and the engine mount cross member agreed (fit) made me believe the engine location fore and aft was correct but I sure have seen pics with more clearance.
dsrracer
pics
Post  hutchjc1 on Tue Aug 16, 2016 10:34 am
PM me your e mail address for pics
hutchjc1
Re: Intake Problem
Post  dsrracer on Tue Aug 16, 2016 12:11 pm
Sent
dsrracer
Re: Intake Problem
Post  Arthropraxis on Tue Aug 16, 2016 1:44 pm
I slotted the mounting holes in the front and rear cross members to slide the whole drivetrain backward to get some room.
Re: Intake Problem
Post  dsrracer on Tue Aug 16, 2016 1:54 pm
Hadn't considered that. I've seen Pics complaining about the space and they already had almost 4 inches clearance. I started with 2.8 to the hood latch. I'm starting with a 951, not sure if that is different than the NA baseline but I'd need to make some really long slots unless there is some other issue I have that's unique.
dsrracer
Re: Intake Problem
