March 2019
Brake pedal return spring
Post  944-v8 on Sun Aug 07, 2016 2:03 pm
I'm having a heck of a time finding where the return spring for the pedal mounts. This is so the brake lights work. I have mechanical brakes with Tilton MS and a hollow brake pedal. There is the hole above the clevis hole, but where does the lower end of the spring mount. There is a hole in the brake switch mounting bracket that is used for a tyrap to hold a wire bundle. Can't believe it goes there. Impossible to connect both ends of the spring from what I've tried. That's the only location I can find. Has anyone use a different spring/method. I just can't remember how that spring mounts. Any suggestions welcome.
944-v8
Re: Brake pedal return spring
Post  murrayg on Sun Aug 07, 2016 11:50 pm
With the pivot bolt out, install the spring on the pedal. Then work the pedal back into position and reinstall the bolt. That's how I did it.
Gord.
murrayg
Post  944-v8 on Mon Aug 08, 2016 2:02 pm
Thanks: Did you use the hole I referred to that is used to tie-wrap the wire bundle, or somewhere else?
944-v8
Post  murrayg on Mon Aug 08, 2016 2:13 pm
Sorry, I did it 2 years ago. I don't remember which hole. Been in Italy for the past 20 months, Italian wine is 5 bucks a bottle......just don't remember!
Ciao,
Gord.
murrayg
Post  944-v8 on Sat Aug 13, 2016 12:42 pm
Yes the wine in Italy is great.
944-v8
