» NDog52's 1986 NA 5.3 Build
Steering Shaft Trouble SBC EmptyToday at 11:30 am by Gutterboy
Steering Shaft Trouble SBC EmptyYesterday at 6:12 am by Colibri Green
Steering Shaft Trouble SBC EmptyTue Mar 26, 2024 3:29 pm by Blaizefed
Steering Shaft Trouble SBC EmptyTue Mar 26, 2024 1:30 pm by Raymond-P
Steering Shaft Trouble SBC EmptyTue Mar 26, 2024 8:49 am by 948
Steering Shaft Trouble SBC EmptyWed Mar 20, 2024 11:52 pm by Raymond-P
Steering Shaft Trouble SBC EmptyWed Mar 20, 2024 1:17 pm by Rob44
Steering Shaft Trouble SBC EmptyTue Mar 12, 2024 3:22 pm by dcoutofstep
Steering Shaft Trouble SBC EmptyTue Mar 12, 2024 2:10 pm by dcoutofstep
Steering Shaft Trouble SBC EmptyTue Mar 12, 2024 12:12 pm by ndog52
Steering Shaft Trouble SBC Empty Steering Shaft Trouble SBC
Post  mred2nice Thu Aug 04, 2016 9:00 pm
Hello There Everyone.
I am moving right a long,finally, on my project and I ran into some trouble tonight. I am working with SBC, 2piece belhousing/adapter combo and the motor mounts from texas performance concepts. I have those shorty Sanderson headers. I put the manual rack back in the car and the header is right in the way of where the steering shaft connects to the rack.
Is there a different rack I need with shorter splined shaft coming out of it to change the angle? Are the Sanderson shorty headers not the hot ticket? What are you all doing on yours?
Ed
mred2nice
Steering Shaft Trouble SBC Empty Re: Steering Shaft Trouble SBC
Post  948 Thu Aug 04, 2016 10:32 pm
What header do you have on the DS, it should be a CC90 IIRC?
Post  mred2nice Thu Aug 04, 2016 10:43 pm
I am not sure. Is that  sanderson part number? Or is that a diff brand? I will look in the morning for a part number.
Thanks for responding,
Ed
mred2nice
Post  spence Fri Aug 05, 2016 6:51 am
Ya, you need two different sanderson headers for this to work. I do not know the part numbers you will have to search on here
Post  mred2nice Fri Aug 05, 2016 6:54 am
Gotcha...thx.
mred2nice
Post  948 Fri Aug 05, 2016 7:35 am
CC90 for the DS and CC2 for the PS.
The face of the CC90 collector flange should almost be on a horizontal plane when installed on the engine. The CC2 is a block hugger, if you install that on the DS it most certainly would interfere with the steering shaft.
Sanderson's website has several images of the CC90.
Post  mred2nice Fri Aug 05, 2016 8:41 am
Ok makes sense now. I have the block huggers. I will have to sell mine and get the correct ones. They are new and coated. Hopefully not too much trouble to sell.
mred2nice
Post  948 Fri Aug 05, 2016 7:35 pm
If you have the CC2 set you will need to keep one for the PS. Call Sanderson and order 1 CC90 for the DS.
Post  mred2nice Fri Aug 05, 2016 11:46 pm
Excellent tip...thanks. Do you know where I can get those bolts that hold the back part of the front a-arms? They look to be metric and have a taper on the end.
mred2nice
Post  962porsche Sun Oct 30, 2016 7:06 am
sanderson states the only kit needed is the CC90 kit.
the CC2 is a block hugger and the CC4 has it's collector straight up and down take one header from each kit and you get the CC90 kit .
962porsche
962porsche
Post  turbobob924 Tue Nov 01, 2016 12:42 pm
subscribed..
Better option than cutting up the hookers?
turbobob924
turbobob924
http://www.turbo924.com
Post  962porsche Wed Nov 02, 2016 7:04 am
i just ordered a cc90 set for a customers car .
on all the other 948's we have built we build our own headers we will see how good the sanderson's will fit . i was told because of the straight plugs for the heads on this motor we will have to heat and dimple the headers were the plugs are . because of this and we are hot coating the hole exhaust system i bought the headers in bare steel .
962porsche
962porsche
