Anyone have issues getting the car low enough?
+2
zeusrotty
6 posters
Okay so to explain, I am using 3/8 inch spacers with Racers Edge camber plates and I don't seem to have enough shock threading to lower it enough for track use. Anyone have any thoughts.
zeusrotty- Posts : 444
Re: Anyone have issues getting the car low enough?
Shorter springs! When I upgraded to 800 and 900, I had to run 6" springs.
Lemming wrote:Shorter springs! When I upgraded to 800 and 900, I had to run 6" springs.
Ah!!! That would do it!!!! lol So easy!!! And I am running 800 in the front and 900 in the rear... Where do I get them? I have Ledas.
https://www.facebook.com/groups/1380380912286834/
http://www.swiftsprings.net/
This place carries just about every spring you could imagine.
What spring rates are you guys running? I have full Racers Edge and Elephant Racing Bearings and bushings. Leda Coilovers with 700 in the front and 900 in the back? Sound good or should I be doing something else?
Or notch your hood, grind your throttle body and remove the spacers...like i did.
v8944- Posts : 211
bluehellfire666 wrote:Or notch your hood, grind your throttle body and remove the spacers...like i did.
this thread has nothing to do with crossmember spacers, engine height or hood clearance.
Just watch your radiator height when you get lower.
I learned the going through a dip from a parking lot to the street that my newer bigger radiator is the lowest piece in the front. It hit hard, and had to weld the top where the steel supports posts went through the aluminum radiator.
Lesson learned.
Lesson learned.
jHo- Posts : 42
