» Passenger footwell
Wed Dec 12, 2018 1:41 pm by Porsche951toLS3
» 85.5 944 LS Adventure
Wed Dec 12, 2018 12:55 pm by ryan08
Tue Dec 11, 2018 10:09 pm by sharkey
» Problem with Dual Remote Vacuum Boosters
Tue Dec 11, 2018 12:37 am by Porsche951toLS3
» 1984 Tach wire
Mon Dec 10, 2018 10:54 am by Rich L.
» 1984 944 Tach and Temp wire color
Sun Dec 09, 2018 1:58 pm by Punisher948
Sat Dec 08, 2018 9:03 pm by robschwieb
» LS Parts for sale
Thu Dec 06, 2018 10:04 pm by Porsche951toLS3
» Dual headlight motor conversion
Wed Dec 05, 2018 8:39 am by 948
» WTB - LS Conversion Oil Pan & Pickup
Mon Dec 03, 2018 10:21 am by cazbah362
December 2018
3456789
10111213141516
17181920212223
24252627282930
31
Differences between Turbo Radiators
Post  superman22x on Tue Aug 02, 2016 11:27 am
I read in a thread here that the early 951 radiator is different than the later years, and would not be sufficient for cooling an LS engine.  What year 951 radiators were these?  I wasn't able to find any more info online. I was going to buy an 86 turbo radiator for my swap project. Part number: 951.106.031.01
superman22x
radiator
Post  hutchjc1 on Wed Aug 03, 2016 7:47 am
I ended up using an aluminum radiator listed on ebay, if you search 944 radiator it will pop up, GPI racing, 280 bucks, has all of the ports needed ( I have an 86 turbo / LS1 ) not sure what you are running. I had to space mine up 1 inch from the bottom shelf so I used a piece of material call 80/20 [You must be registered and logged in to see this link.] you can find some on ebay it gave me the height I needed to use the stock upper bumpers and provided a lower mounting point for the stock fans to mount. 80/20 makes for a very easy mounting system as it allows the use of "floating hardware" so it's very forgiving to fabrication "tolerances".
hutchjc1
Re: Differences between Turbo Radiators
Post  superman22x on Wed Aug 03, 2016 8:03 am
Did you run the aluminum radiator because the 86 turbo radiator was insufficient? Or just decided to run that from the beginning?
superman22x
Post  hutchjc1 on Wed Aug 03, 2016 8:19 am
Seemed better at the time then starting with a radiator that had 90 k on it and the new one had a bit more cooling capacity. My car has heads, cam,and intake and so far on a 96 degree day sitting in traffic the highest temp I saw was 207 f. using the stock fans and I added redline water wetter just as a cheap "just in case". I have not added the a/c system yet so we will see how it does once the condenser is in front of the radiator....
hutchjc1
Post  jHo on Wed Aug 03, 2016 9:52 pm
I got mine through TPC. And it shipped from Superior Radiator in Mount Clemens, MI. When I talked to friends I know living up that way, they totally recommended Superior for any custom radiators. Also the flier that came with the radiator lists all the different LS swaps they supply. so I'd say they have plenty of experience. And I can say the radiator looks great (my car is almost done, so I don't know how it performs yet). My car started as an N/A with the original radiator, so I was swapping mine out for sure. Plus, I'm going with a crate LS3, so I wasn't then going to skimp on the radiator. Just my 3 cents.
jHo
Post  FrostedFlakeJake on Thu Aug 04, 2016 6:44 am
FYI the guys at superior radiator are great and do great work. They are local to me, No idea they supplied TPC.
FrostedFlakeJake
Post  superman22x on Thu Aug 04, 2016 10:20 am
I didn't realize you were in Michigan as well. I'm over in Farmington Hills, MI.
superman22x
Post  FrostedFlakeJake on Thu Aug 04, 2016 10:21 am
superman22x wrote:I didn't realize you were in Michigan as well.  I'm over in Farmington Hills, MI.
No $#**!!! I just bought a house in Novi. We'll have to connect sometime.  rabbit
FrostedFlakeJake
Post  superman22x on Thu Aug 04, 2016 11:33 am
For sure, I work up in Milford as well. Always passing through Novi.
superman22x
