944 - SBC Input Shaft Crank Bearing EmptyYesterday at 11:51 am by geegeesbits@gmail.com
944 - SBC Input Shaft Crank Bearing EmptyMon Jan 27, 2020 2:27 pm by Porsche951toLS3
944 - SBC Input Shaft Crank Bearing EmptySun Jan 26, 2020 4:51 pm by j7wolfe
944 - SBC Input Shaft Crank Bearing EmptySat Jan 25, 2020 6:42 pm by kevin924kevin
» Pedal Assembly - Which one?
944 - SBC Input Shaft Crank Bearing EmptyTue Jan 21, 2020 5:27 pm by Hotrodz of Dallas
944 - SBC Input Shaft Crank Bearing EmptySat Jan 18, 2020 7:15 am by Rothaus
944 - SBC Input Shaft Crank Bearing EmptyThu Jan 16, 2020 6:51 am by 87944turbo
» 82 924 with AUX Audi V8.
944 - SBC Input Shaft Crank Bearing EmptyThu Jan 16, 2020 2:11 am by Golten1986
944 - SBC Input Shaft Crank Bearing EmptyTue Jan 14, 2020 2:48 pm by Gumby
944 - SBC Input Shaft Crank Bearing EmptyTue Jan 14, 2020 6:43 am by 87944turbo
January 2020
6789101112
13141516171819
20212223242526
2728293031
944 - SBC Input Shaft Crank Bearing Empty 944 - SBC Input Shaft Crank Bearing
Post  mred2nice on Sun Jul 24, 2016 9:53 pm
Good Day everyone!
Exciting day today. I test fit the motor down in the engine bay. I wanted to check out how far in the crankshaft bearing the tip of the splined shaft fit so I just had the bellhousing and spacer on. I want to use that spacer plate for block protection. How much of the tip needs to be in the bearing?
Ed
mred2nice
944 - SBC Input Shaft Crank Bearing Empty Re: 944 - SBC Input Shaft Crank Bearing
Post  spence on Mon Jul 25, 2016 8:11 am
If the flywheel ever exploded, you should be more worried about what its gonna do to your feet and legs rather than your engine block. Lol
Post  mred2nice on Mon Jul 25, 2016 9:09 am
I am going to try and fit a composte csi shield for a turbo 350 or a tci flexplate shield. I just want to make sure their is enough engagement with the bearing so I can use the spacer plate.
mred2nice
