rear bump stops
Page 1 of 1 • Share •
rear bump stops
It appears like on my 85.5 that there is a pad where a bump stop should be on the trailing arm. Does anyone have bump stops on theirs, or know if there are supposed to be any? I'm hoping I can put some there to keep my tires out of the fenders on launch but maintain factory ride otherwise.
lsporsche- Posts : 72
Re: rear bump stops
I thought I posted dimensions of the ones I made that adapted the VW poly bump-stops to the trailing arms...
xschop- Posts : 2710
Re: rear bump stops
I believe the old vw camper vans used p/n 211501191. Mount & fit same as 944...just taller.
https://www.google.com/?gws_rd=ssl#newwindow=1&q=211501191
944convert- Posts : 253
Re: rear bump stops
Mine mounted the shorter bullet style mounts that come in rubber or poly.
Re: rear bump stops
Hugh, don’t remember that one, and I thought I had stolen all of your good ideas.xschop wrote:I thought I posted dimensions of the ones I made that adapted the VW poly bump-stops to the trailing arms...
racertomtom- Posts : 143
Re: rear bump stops
Just dont steal my bad ideas. You'll loose all respect.
I think I have a spare set somewhere if I cant find dims. Pic
Re: rear bump stops
944convert, do they still work despite being taller? They look like they would sit in that bowl well, but how exactly do they mount? Looks like a nice, inexpensive option.
xschop, I tried searching for anything bump stop related in this forum and came up empty, but I know the search function can be finicky.
Re: rear bump stops
On one car we wound up trimming about 3/8" or so off the top of the bullet to give the car more squat and a better launch.
Re: rear bump stops
How did this mod work out for you? It seems like you were having launch issues. Prevents cut tires with soft springs? I assume you drill and tap the trailing arm casting where the stop should have been. The area where it would hit the frame looks kinda rough/sharp, did you put anything there?
Re: rear bump stops
simply pull off the existing rubber bump stop and push the replacement onto the mount's metal nipple.lsporsche wrote: but how exactly do they mount? .
Re: rear bump stops
Correct. The arms were just drilled/tapped and a simple slight hammer job to the wheel well area. This was a simple and effective solution on a couple 951s that did some drag strip time but also were Dailys. No rear coiloers and torsion bars to mess with.
Re: rear bump stops
Do you sell those bump stops as a kit xschop?
Re: rear bump stops
I can make you a set of the aluminum spud adapters then you get the poly mounts from fleabay. Just pm.
Re: rear bump stops
I spun you a set out. Will get in mail mon.
Heres the dims for anyone else. You can drill 5/16" or 8mm thru-hole and just tap your control arms accordingly.
Re: rear bump stops
That's convenient, Thanks!
Re: rear bump stops
how do you get the rubber ones to hold there is no hole to put a bolt in there
matt889- Posts : 184
» Commander rear seat and cage.
» Installing EMP's HD rear bumper for the Rhino
» Rhino Rear Brake?????
» rear seats for prowler or any sidexside
» RZR rear mudflaps
» RZR rear mudflaps
» LSA Supercharged 86 Porsche 944
» LS Conversion Kit Plus
» tips on removing headers?
» Oil Pressure
» Mass oil leak!?
» SBC Pilot Bearing
» 924 Twin Turbo 5.3 C5 T56 swap!!
» Lighten clutch pedal feel?
