» Dual MC Mounting Bracket
Yesterday at 10:02 pm by 948
» LS1 1st start
» Need help! Car won’t start
» Brand new ls3 build
» Lighten clutch pedal feel?
January 2019
78910111213
14151617181920
21222324252627
28293031
Length of power steering line with hydroboost
Post  FrostedFlakeJake on Wed Jun 22, 2016 11:03 am
So it's almost cheaper for me to buy pre-made power steering lines than putting them together myself...
Anyone who runs the hydroboost system know how long the high pressure lines need to be? Line from pump to booster and from booster to rack?
FrostedFlakeJake
Re: Length of power steering line with hydroboost
Post  superman22x on Wed Jun 22, 2016 12:36 pm
I opted to buy the Russell PowerFlex lines and fittings. A 6ft line was enough with a few inches to spare to make both my lines. I can measure the lengths and show you my routing if you would like. I have 90* fittings on all ends. That was the expensive part really. $17/fitting...
superman22x
Post  FrostedFlakeJake on Wed Jun 22, 2016 1:33 pm
superman22x wrote:I opted to buy the Russell PowerFlex lines and fittings.  A 6ft line was enough with a few inches to spare to make both my lines.  I can measure the lengths and show you my routing if you would like.  I have 90* fittings on all ends.  That was the expensive part really.  $17/fitting...
That would be greatly appreciated. Thanks
FrostedFlakeJake
Post  superman22x on Fri Jun 24, 2016 9:05 am
Looks like my lines are 34" and 32.5". The longer one goes from PS pump to Hydroboost. Both have 90* fittings at the end. I measured from end to end, including the fitting.
superman22x
Post  FrostedFlakeJake on Fri Jun 24, 2016 10:49 am
superman22x wrote:Looks like my lines are 34" and 32.5".  The longer one goes from PS pump to Hydroboost.  Both have 90* fittings at the end.  I measured from end to end, including the fitting.
Thats great! Thanks a bunch!
Looks like I can get them made for $63 with 90s on all ends.... line isn't braided stainless but even so it's cheap! To get just 4 90° fittings from russel or other brand would cost me more than that.....
FrostedFlakeJake
Post  superman22x on Fri Jun 24, 2016 9:49 pm
Nice! I would double check the measurements, since I have AN fittings and routed them my way, so you may need more/less length. But you can use my measurements as a starting point.
superman22x
Post  spence on Sat Jun 25, 2016 10:04 am
If you're getting these made at a hydraulic shop, keep in mind that hydraulic hose does not twist. You have to know the direction of the 90's before you get them crimped. Get the hose and fittings first and get everything on the car, then mark the 90's and hose with a paint marker so the shop knows the orientation. Then take them back to the hydraulic shop and get them crimped and they'll be perfect.
