» JP's LS1 Conversion
Yesterday at 8:32 pm by jpkinerk
Yesterday at 8:13 pm by gdopnt
Yesterday at 9:56 am by superman22x
» LS3 Exhaust
Sat Jan 20, 2018 11:12 pm by sharkey
» Steering shaft short
» ecotec swap
» 86` 944 turbo project
» alignment specs
Fri Jan 19, 2018 4:22 pm by Hotrodz of Dallas
» 1984 Gen IV 5.3 Swap
Fri Jan 19, 2018 2:03 pm by superman22x
January 2018
Crossmember and Suspension spacers
Post  924LS on Tue Jun 21, 2016 7:45 am
Hello! Everyone! I'm also doing an LS swap in my Porsche I know I have to get spacers for my crossmember and have heard I need spacers for suspension as well I was wondering if anyone on here knows the dimensions of the spacer so I can make them myself? That would be greatly appreciated! Thanks!
924LS
Re: Crossmember and Suspension spacers
Post  Arthropraxis on Wed Jun 22, 2016 6:54 am
You can make them yourself. I made some out of 1/4" aluminum.
Post  924LS on Wed Jun 22, 2016 7:47 am
do you know the dimensions?
924LS
Post  Arthropraxis on Wed Jun 22, 2016 12:02 pm
No, I got a piece longer and wider than both of the holes and drilled two holes that would fit the bolts. Once you get the crossmember off you will know what to do.
Post  erioshi on Wed Jun 22, 2016 11:14 pm
Arthropraxis wrote:You can make them yourself. I made some out of 1/4" aluminum.
There is one thing to be careful of when using aluminum to make spacers. If both the chassis and bolts are steel, when aluminum is used for the spacer and it isn't fully painted, powder coated or anodized (inside and out), if water gets between the raw aluminum and any steel, you could end up with some very serious corrosion. The aluminum / steel interface acts like a battery, and water will really accelerate the process.
I ran into this on a time attack car (an Evo). The owner had made some aluminum spacers to push the steel OE sub-frame stiffeners down about 1" to clear a large exhaust. After they had been on the car for about two years the OE bolts had corroded almost completely through, a couple broke off with only light pressure from a ratchet, and the OE threads into the front sub-frame were shot. The whole mess came apart in a shower of white aluminum corrosion after I managed to break everything loose. The OE sub-frame needed to be drilled and re-tapped with larger threads, the OE bolts had to be replaced with a larger size, and the sub-frame braces had to be drilled slightly to fit the new bolts. When the car was put back together we replaced the aluminum spacers with painted steel.
The repair process was a lot of unnecessary work to fix a problem that could have been easily prevented.
It is also worth noting that the aluminum spacers were painted everywhere except the inside of the bolt holes. All of the damage and corrosion started in the bolt holes and worked into the other parts. From the outside everything looked fine except one bolt seemed to be riding a bit high. We went to check it and discovered what was really going on.
erioshi
Post  Arthropraxis on Thu Jun 23, 2016 6:40 am
Thanks, for the info I will check that soon. They have been in my car for several years now.
Post  FrostedFlakeJake on Thu Jun 23, 2016 7:39 am
Mine from texas performance are currently off car. I can give you dimensions when I get home from work.
FrostedFlakeJake
Post  FrostedFlakeJake on Fri Jul 15, 2016 9:28 am
Oh my goodness I thought i responded to you weeks ago. My apologies.
It looks like the spacers are about 92mm long, 38mm wide, and the outer edge of the holes are ~77.2 mm apart. The hole dimension is really the only one that needs to be close. I would recommend double checking it on your car.
I think the holes are for 12mm bolts and they should run straight through the center of the spacer.
[You must be registered and logged in to see this link.][You must be registered and logged in to see this link.] by [You must be registered and logged in to see this link.], on Flickr
FrostedFlakeJake
