Suspension upgrade..Bilstein, Koni or something else
I need to upgrade the suspension on my 84 928s. The car has Bilsteins on it now. I am open to other brands with improved springs. Have you done this upgrade? If so, please share your experience.
Hammerhd- Posts : 23
Re: Suspension upgrade..Bilstein, Koni or something else
What kind of use will the car see? Suspension springs and damper are usually selected based on how the car will be used.
erioshi- Posts : 227
It will be a street car with an occasional aurocross or track day.
Unfortunately I can't be much help to you. The next step on my swap is having the heads ported before I can put the 5.3 back together and get it into the car. Not having upgraded a 928 suspension before I'll be starting with "ideas" and need to refine things as I get results.
Rennlist and possibly pelican should have threads on suspension upgrades; those might be a starting point for spring rates, although you may need to do some extrapolation to adjust the front rates. If you really don't mind a bit of work, there are suspension calculators available that might also be useful, but you'll need to know motion ratios and existing probably existing spring rates. Locostusa.com is a site for homebuilt Lotus Seven clone builders that has lots of good information (and various suspension calculators) if you don't mind doing a bit of math and some measuring.
Are you just struggling with bad dampers or are you looking change the spring rates as well? On my car, I'll probably just start with a good set of dampers (something I can have rebuilt and re-valved for not too much), and adjust spring rates and sway bars based on how the car drives from that point.
» Budget big brake upgrade for early cars aka my Boxster caliper upgrade
» 1987 944 turbo look LS3 swap
» ** SOLD ** Ground Control Adjustable Coilover Conversion Koni Yellow Fronts
