Camber adjustment
Camber adjustment
I am wondering after you guys lower your car how are you gainining enough positive camber Back? I adjusted the eccentric camber bolt but it doesn't seem to have enough motion. After lowering it I was close to 4 degrees negative camber and after adjusting it I'm around high 2 pushing 3 degrees.
yamamtx- Posts : 97
