Use Mustang proportioning valve with hydroboost?
Hi all,
This weekend I got my engine mounted and installed my mustang hydroboost setup. I'm using the mustang master cylinder for now at least. I have the proportioning valve as well. Those that have used the mustang master, did you use the mustang proportioning valve as well? Or just plumb straight into the master, with a tee for the two front brake lines?
The best would be to get an adjustable valve and set it right, but that will come later if needed.
superman22x- Posts : 272
Re: Use Mustang proportioning valve with hydroboost?
When I still had the Mustang master cylinder I used a Tilton adjustable proportioning valve. The bias is significantly off with the mustang MC...
It was off with just the master or with master+mustang bias valve?
Yes to both. You need to go with an adjustable proportioning valve.
Got it, I will order one then. Thanks
It depends on what calipers you are running. If Porsche, you probably will need one. The Lexus/Mazda set up likes that master cylinder.
racertomtom- Posts : 144
Ok, good to know, thanks! For now it will be NA Porsche brakes. Upgrade will be in the near future.
