speed signal out
speed signal out
coming out of the pcm that was set up by TPC there is a wire marked speed signal out, I can not figure out where it should go. car is an 86 turbo pcm and harness are believed to be from a 98 Camaro. Is it needed ? I don't see any need for it but am confused as to why it would have been separated and labeled if there was no need, so what do I do with it ?
Once more thanks for any help !
Jim
Jim
hutchjc1- Posts : 68
Re: speed signal out
Out? My PCM has a speed signal in that's connected to TPC's VSS kit. Tuning can make this signal unnecessary, but my tune uses it to help with idle conditions.
And a question from me. I've installed Boxster ABS that has a speed signal out. Can I connect this to the PCM's speed signal in? Or is it likely the Bosch speed signal out differs from what the Chevy PCM gets from the VSS sensor?
would you guys know the pins for the VSS kit at tpc on PCM ? do we plug this to the pins on the pcm that are for the Transmission VSS or the wheel speed sensors ( i have a truck engine and computer -.- )
2005 express van 2500 with a 4.8 engine for reference . and on my pcm pin out there is a few *VSS* signals and references
matt889- Posts : 214
Today at 12:47 am by sharkey
