Remote Oil Filter Location?
Where have you all been mounting the remote oil filter bracket? I have -10AN outlets on the pan, like the Moroso 20140 (the SummitRacing copy). There doesn't seem to be much room below the car. My thought was on top of the driver side frame rail, with the filter mounted horizontally. Anyone have better ideas?
superman22x- Posts : 272
Re: Remote Oil Filter Location?
Mine is on the outside of the passenger side frame rail, mounted there with my Accusump. My oil cooler is cross flow so dumps out on that side. Filter is mounted vertically to enable filling it up before screwing it on at oil changes.
Mine is mounted on the right side of the engine using the a/c bracket.
Not a great picture but you can see the filter..
Techno Duck- Posts : 447
Hi Super,[You must be registered and logged in to see this image.]
My filter is located in an unconventional place, but it's worked out perfect. The lines are shorter and are routed away from the headers and up the firewall where there is a ton of room. Changing the filter is a breeze, It's high enough for a baking pan to slip under and catch all the oil when it's removed.
ciao,
Gord.
p.s. It's by the battery if you can't spot it!!
ciao,
Gord.
murrayg- Posts : 105
I have mine mounted on the right side of the drivers side frame rail. Works well with the oil cooler mounted in front.
» those with remote oil filter...
» Remote Oil Filter Lines for use with the LS1
» Canton 22-630 remote oil filter adapter
