» What dipstick??
Today at 2:46 pm by chrenan
Today at 10:25 am by superman22x
Yesterday at 9:18 pm by carr911
Yesterday at 9:12 pm by carr911
Yesterday at 9:09 pm by carr911
Yesterday at 4:11 pm by sparkydog
» Hello, Gentlemen.
Yesterday at 8:35 am by LStuner
» WTB: 944 Turbo Roller
Mon Jun 18, 2018 11:38 am by chrenan
June 2018
Which chassis to start with?
Post  racertomtom on Wed Mar 23, 2016 8:51 pm
If you guys had a choice for your conversion between a 1985.5 944 N/A and a 1988 944S, which would you choose and why? Both bodies and interiors are in comparable shape, similar mileage, everything will get gone through, ignore transaxles.
racertomtom
Re: Which chassis to start with?
Post  944convert on Wed Mar 23, 2016 9:09 pm
Does the 944S have the ABS braking system option?
Post  racertomtom on Wed Mar 23, 2016 9:31 pm
944convert wrote:Does the 944S have the ABS braking system option?
No
racertomtom
Post  sharkey on Wed Mar 23, 2016 11:29 pm
id do the 88 s. the 88 has the wider suspension and better spindles. also should have the brembo brakes on it.
Post  FrostedFlakeJake on Thu Mar 24, 2016 6:16 am
Wheel choices with the 88 are going to be more abundant if you want to run wider wheels. Easier/cheaper than running spacers.
As mentioned earlier the spindles are also stronger and more desirable.
FrostedFlakeJake
Post  racertomtom on Thu Mar 24, 2016 11:01 am
What about speedometers, VSS etc.?
racertomtom
Post  Techno Duck on Thu Mar 24, 2016 1:45 pm
Both the '85.5 and '88 speedo is run off a sender on the transmission. VSS can be hooked up with the kit from TPC that puts a pickup ring on the CV joint.
Post  docwyte on Fri Mar 25, 2016 8:04 pm
Neither. I'd rather start with an 88 Turbo S or 89 Turbo. After that I'd go with an S2 that has the M030 option, than an 87 Turbo than an S...
Post  racertomtom on Fri Mar 25, 2016 10:35 pm
Does anybody know if an ABS stub axle will fit the ’85 trailing arm? In other words, is the length the same?
docwyte wrote:Neither.  I'd rather start with an 88 Turbo S or 89 Turbo.  After that I'd go with an S2 that has the M030 option, than an 87 Turbo than an S...
Why?
racertomtom
Post  sharkey on Sat Mar 26, 2016 2:38 am
sure, start with the best ones they made. when money isnt a concern thats ideal, however where i am those cars are in the $15-20k range (canadian dollars) in decent shape. a typical 85.5+ n/a car is $3-5k.
Post  docwyte on Sat Mar 26, 2016 10:18 am
Better brakes, better suspension, better transmission. Saves you money in the long run.
Why buy a "cheap" car that you then have to spend thousands more on to upgrade everything on?
You should be able to find a decent one with a bad motor for less....
Post  sharkey on Sat Mar 26, 2016 11:17 am
it really depends on what you can buy one of them for. yes, you wouldnt have to do a brake upgrade on one of those cars, and you do start with a better transmission. to me, the suspension is a wash, odds are your going to have to have struts rebuilt/replaced on a car of this age, and will end up wanting different spring rates.
i know that with my swap, which includes a brake upgrade, total cost thus far leaves me money left over for an AOR transaxle and a half decent set of coil overs compared to just the cost of buying any of the turbo s cars i looked at in my area
Post  racertomtom on Sat Mar 26, 2016 11:42 pm
You start out with a cheap car because all you really need is a good body to do a ground up build. The turbo models might have better parts but they’re still inadequate parts for my liking so they would also get replaced. That leaves way too high a starting point unless you already own one or find a super good deal on one equipped with LSD and big sway bars. I gave $800 for the ‘85.5 and $900 for the ’88 equipped with LSD. I’ll be OK in the long run.
My plan was to repair the 85 and build the 88, in the process I discovered the 85 was locked up. Now I’m simply rethinking the plan.
racertomtom
