Poor shifting
+4
matthewb
simon123
mr965
8 posters
Poor shifting
I've noticed a few people had the same issues I'm dealing with and I have not found a solution yet.
LS2 swap with difficulty in engaging 1-2 and Reverse when hot.
Intermittent grinding shifting 2-3 and 4-3.
I just had new syncros done and a new Spec stage 1 clutch.
Currently have 7/8 Tilton m/c. XSChop short shifter. Also have swapped fluids from gl5 and gl4 with no improvement.
This would be a great track toy if it would only shift like my 951.
Is there anyone with suggestions on what else to check? I have no hair left to pull out.
Any assistance would be greatly appreciated.
mr965- Posts : 20
Re: Poor shifting
Remove the rubber inspection cover on the back of the torque tube bell housing (transmission side). With the car idling, have someone push the clutch down while you visually verify that the input shaft on the torque tube stops spinning. Do this with the car cold and hot. This will narrow down your issue to being clutch / pressure plate release, linkage or transmission.
Techno Duck- Posts : 447
Poor shifting
I have a similar problem with First/second gears. I have a short shifter and I believe that its geometry is causing the problem. Shifts fine in 3,4,5 and reverse.
Planning to go back to a long shifter but I threw it away.
simon123- Posts : 125
Re: Poor shifting
I do believe the problem has been diagnosed. The nub on the end of the drive shaft is worn and the pilot bearing does not fit snugly. This is time for a rebuild or replacement. I am fortunate enough to have found a local machinist to add material to reshape the nub to spec. I will be shaking the car down on Thur and feel confident this is the solution.
mr965- Posts : 20
Re: Poor shifting
mr965,
Did the repair pilot diameter fix your problem? My shifting has been a little bit poor and "notchy" and I have been trying to pinpoint it.
matthewb- Posts : 53
Re: Poor shifting
Success! It now shifts smoothly all the time. very good info was also found at www.blackseard.com
hope this helps!
hope this helps!
mr965- Posts : 20
Re: Poor shifting
mr965 wrote:Success! It now shifts smoothly all the time. very good info was also found at www.blackseard.com
hope this helps!
Good information. I never checked the input shaft diameter in the pilot bearing. How well does a 944 shift normally? From everything I have read it seems they all shift kind of notchy. I have had my transaxle rebuilt and it didn't shift much better. Well, prior to blowing the third gear.
Re: Poor shifting
Arthropraxis wrote:mr965 wrote:Success! It now shifts smoothly all the time. very good info was also found at www.blackseard.com
hope this helps!
A 944 normally shifts a little notchy as in you will feel the gates. It is not at all like a Honda or BMW buttery smooth. Almost like a well damped American shifter as in an old Muncie
mr965- Posts : 20
Re: Poor shifting
Sounds like mine is fine then. Still good info. My spines don't fit the driveshaft properly, it will probably need to be rebuilt when the clutch needs replacing.
Re: Poor shifting
Mr 965 do you recall the clearances that were used for the adding of material and the pilot bearing?
gdopnt- Posts : 127
Re: Poor shifting
gdopnt wrote:Mr 965 do you recall the clearances that were used for the adding of material and the pilot bearing?
The pilot bearing inner diameter is 15mm... The tip also needs to be 15mm; its a "slip fit". Not sure what your asking here?
Re: Poor shifting
mr965 said his tip had material added and turned down to spec, was wondering what his numbers were because he said his shifting improved after that repair.
gdopnt- Posts : 127
Re: Poor shifting
Is this something a driveshaft shop can accomplish? Or a machine shop?
Re: Poor shifting
The typical repair for this is machining down the end of the drive shaft that engages the pilot bearing, then pressing on a sleeve to make up the difference. Infact i remember RockAuto at one point had one of these sleeves listed, i thought it was strange as its not something you typically see at any other major part supplier for our cars.
» 1st and 2nd gear hard to get into when hot.
» Clutch slave remote speed bleeder
» Still need guidance with a shifting issue...
