» Tpc LS adapter plate
» Headers, headers, HEADERS!
Assembly lubricant
Assembly lubricant
Post  ffmedic on Sat Oct 24, 2009 5:01 pm
Ok call me a dumbass but I am posting this in case others don't know this:
Ok I thought I was smart as all get out bought some ARP assembly lubricant lubed up the cam lobes,cam retainer, and the pushrod tips with it.
So I had my brother come over and help me on setting the valve lash on the engine when I mentioned oh look what I did and put this arp lubricant on the pushrods, and that's when I found out I made a HUGE did I say HUGE mistake affraid No . Ok incase anyone else makes this mistake or is about to make this mistake arp assembly lubricant is only to be used on the threads and under the bolt heads of bolts being torqued not to be put on ANY parts. Use oil or the proper lubricant and make sure you read the instructions before you use any ( nope I didn't, I didn't have to it said right on the bottle ASSEMBLY LUBRICANT right ahhh no). I hope this saves someone else the frustration of tearing down the entire engine assembly like I had to in order to clean everything off, otherwise you just might tear up some parts way before their time is due on your brand new rebuilt engine or that nice new cam you just installed.
ffmedic
lock er down
Post  xschop on Sun Oct 25, 2009 7:22 am
Basically you Loc-tite'ed your cam in.
Dude, I don't know if there is an emoticon for this one.
If it hasn't set up, you can clean it off with acetone. If it has set up, an SCBA respirator and thick Nitrile gloves with some methylene chloride might save your ass.
Re: Assembly lubricant
Post  RobotMachines on Sun Oct 25, 2009 10:39 am
Damn, glad you and your bro caught it. You would think by the name that it's just a lubricant... yikes.
RobotMachines
Post  948 on Sun Oct 25, 2009 9:31 pm
Though it is not ideal, having that lube on your bearings etc is not that bad. It is a moly based lube, like EP grease or engine assembly lube.
In addition to engine assembly lube; prime your engine before its first start.....remove plugs, pull the FP relay and crank the engine till you get full pressure on the OPG. cheers
Post  ffmedic on Mon Oct 26, 2009 11:01 am
xschop wrote:Basically you Loc-tite'ed your cam in.
No not like loctite , but bad enough though.
I had np pulling everything apart and cleaning everything off.
I do have to say though after that screw up thank gawd my brother came over and thank gawd I and he said something.
How did he know about that I screwed up , well guess it runs in the family line because he learned the hard way on this one he smoked a cam he installed on his mustang! affraid
ffmedic
Post  v8carreragts on Sun Nov 01, 2009 1:05 am
Nitrile won't work with methylene chloride, they will fall apart. You need butyl rubber or polyvinyl alcohol (PVA) gloves.
