» Dual MC Mounting Bracket
Yesterday at 10:02 pm by 948
» LS1 1st start
» Need help! Car won’t start
» Brand new ls3 build
» Lighten clutch pedal feel?
January 2019
78910111213
14151617181920
21222324252627
28293031
Rear caliper choice for LS430 setup
Post  jpkinerk on Sun Mar 06, 2016 7:51 pm
Every once and awhile I see people talking about running RX7 rear calipers with their LS430 front calipers. I've been running stock 944 turbo rear calipers with my LS430 calipers, using a BMW hydroboost and 5/35 proportioning valve. It seems fairly well-balanced, but I don't know what I don't know. Ya know?
jpkinerk
jpkinerk
Re: Rear caliper choice for LS430 setup
Post  xschop on Sun Mar 06, 2016 8:02 pm
As long as you are balanced then you are good to go. The RX7 calps have a little larger pad and piston area. I've been in on two hybrids with them. One with balance bar which was pretty good for manual brakes, but the hydroboost and the combo was astounding.
Post  87wolfsburg on Tue Feb 07, 2017 4:54 pm
what rotors are you using with the rx7 calipers? and what year rx7?
87wolfsburg
Post  sharkey on Tue Feb 07, 2017 5:35 pm
the original swap was used with fd rx7 calipers (93-95 in north america), however for a short time i used fc turbo calipers. they are the same basic design, same piston size, same pad size and same bolt pattern, the fd calipers just look a little better. the rx7 caliper swap was designed to be used with 86 944 turbo rotors for 86 and earlier cars, and 87+ turbo rotors for 87+ cars.
