Fittings make sure you get the right one
The reason I am posting this is because of an issue I recently came upon. Feel free to add to this thread though if you have any added information.
Ok I have been searching for a 1/8th pipe to a 4an for hydraulic throwout bearing, this is what I found out: one you need a high pressure fitting and they are a bitch to find, I found one at summit's site and after ordering it for like $3.00 and get this $4.95 shipping I received it ,of course right after I got the fitting I was reading somewhere or watching a hotrod show or something aluminum fittings are not high pressure.
So it got me thinking A) did I get the right fitting= answer no , so of course I checked around some more and I could not for the life of me find a high pressure fitting that went from 1/8th to 4an.
That is until a friend of mine took me to a shop that does all hydraulic lines and sells all the high pressure fittings I would want. (btw thanks JD) And it cost a whole $1.53 without shiping because they had it in stock.
So if your having issues like mine check the yellow pages for something local that works with or just makes high pressure lines.
The place I went was called parker I believe their located in southgate michigan.
ffmedic- Posts : 103
Re: Fittings make sure you get the right one
yikes, good advice, how high pressure is 'not high pressure' are we ok to use the aluminum ANs in power steering?
Tetzuoe- Posts : 178
Nooooooooo don't use aluminum fittings in the power steering unless it is only on the low pressure side.
Their is a high pressure side and low pressure side(low being the hose that goes into the cannister that holds the fluid that is not under pressure).
Once it enters the pump it becomes under pressure and from my understanding , it's under like 1500 to 2200psi.
If your using a hydraulic throwout bearing those hoses are under high pressure as well.
So no don't use aluminum fittings for those (unless their are specifically made for high pressure).
If I am wrong please let me know and everyone else know as well.
Dave
Dave
Yoou need steel fittings. Aluminum will burst.
Try here
Try here
v8carreragts- Posts : 332
Just because its aluminum doesn't mean it will not withstand 2000 psi. We have 5000 psi gas cylinders at work that use aluminum end fittings. The fitting should have a published pressure rating, go by that. Also high pressure is a relative term and isn't very meaningful. 2000 psi would typically be considered low pressure in many applications. The advice on industrial hydraulic hose supply is very good. The stuff is cheap in comparison to the aftermarket performance parts, just not quite as sexy.
Rob
Rob
5.0L951- Posts : 2
That is true, but unless you know for sure don't use aluminum for this application. I worked as an engineer in the industral hydraulic industry for some time. Typically, low pressure is 0-3000 PSIG, medium pressure is 3000-6000 PSIG and high is above 6000 PSIG. But pressure is a relitive turm. It all depends on what you are talking about.
You need to use fittings that have a documented pressure rating. I worked with pressures up to 150,000 PSIG and have worked on determining the cause of failure for many lawsuits. I have seen what happens when someone uses the wrong fittings or hose and causes catistrofic failure. USE ONLY CORRECTLY RATED FITTINGS AND HOSE!
