Power steering rack still fail after Turn one pump install....
when i first finsih my conversion, it did not take too long i had leaking rack( at that time it was pretty bad all the fluid dump out in a min or so even large smoke coming out from hood)
decide to keep the PS rack, went out to buy a porsche dealer rebuild rack, drive a year or so no problem
decide to upgrade to upgrade Turn on pump. for instance i notice the steering is a bit heaver and when idile with brake on the car seen to idile better mabe this is from pump is lighter to spin
long story short, about 1 week ago i notice the noise power pump sure enought the rack is leaking again
any idea how to improve it ? install smaller restricter from turn one to reduce the pressure once again ?
or any other PS fluid might help this
i have pretty wide wheel at front and i do a lot of lock to lock u turn on street i hope this is not reason
to kill rack
to kill rack
Diyman25- Posts : 79
» Turn one power steering pump.
» High pressure hose from rack to power steering pump for LS swap
» WTB: Power Steering rack
