» Dual MC Mounting Bracket
Yesterday at 8:11 pm by 87944turbo
Yesterday at 7:50 pm by hp18racer
Yesterday at 5:20 pm by dougr944
» Need help! Car won’t start
Yesterday at 3:51 pm by jess2suityou
Yesterday at 9:44 am by keetle
» Brand new ls3 build
Yesterday at 9:32 am by Plucky948
» Lighten clutch pedal feel?
Yesterday at 1:35 am by Porsche951toLS3
January 2019
78910111213
14151617181920
21222324252627
28293031
Here's some good tunning / scanning software info for the LT1
Post  spence on Sun Feb 21, 2016 7:19 am
Here's some good tunning & scanning software for the LT1 engines. I have used Tunercats and Datamaster. Both are good programs; I have recently started looking into some free tuning & scanning programs which are Tunerpro (tunning), EEhack and scan95 (scanning & data logging). These programs are just as good if not better than tunercats and datamaster.
Scan95-------------> [You must be registered and logged in to see this link.]
Tunerpro ----------> [You must be registered and logged in to see this link.]
Tunerpro EEX file definition-------------> [You must be registered and logged in to see this link.]
EEhack--------------> [You must be registered and logged in to see this link.]
These three programs are all you need to tune and scan your LT1 engine. You create your tune in tunerpro and you can flash it with EEhack.
EEhack will also datalog, adjust timing advance in real-time, adjust open loop AFR in real-time, test idle target speeds while adjusting timing and fuel to nail the perfect idle, enable/disable fans, closed loop and a AFR analyzer. It also allows you to hook up a pin from the ECU just for a wideband sensor.
You can read about it here ---------> [You must be registered and logged in to see this link.]
Scan95 is very good for scanning codes and data logging.
Just thought I'd share.... Not sure how many guys actually have the old LT1 engine.
Re: Here's some good tunning / scanning software info for the LT1
Post  948 on Sun Feb 21, 2016 9:21 am
My "old" LT1 is still running strong, there are some of us still left.
It never even occured to me that there might be some newer options out there; i started using Tunercat and Datamaster at least 10 years ago.
Thanks for sharing.
