March 2019
Hydroboost install
Hydroboost install
Post  hutchjc1 on Mon Feb 08, 2016 11:37 am
I have seen a few folks mention a write up for the hydro boost installation but have not been able to find one, has anyone written anything to act as a guide ? I am using the ford booster with the adapter and Porsche master and any advice from the folks that have installed theirs would be a great help. Looking for things like do you install the mounting plate first and then the booster or do you mount the booster to the plate and then install, not sure how you could get to the "nut " on the booster and add the snap ring from under the dash, any first hand knowledge would be great.
Thanks again for the help !
Jim
Last edited by hutchjc1 on Mon Feb 08, 2016 11:39 am; edited 1 time in total (Reason for editing : spelling)
hutchjc1
Re: Hydroboost install
Post  Techno Duck on Mon Feb 08, 2016 8:29 pm
To sum it up, its a major pain in the ass!
I would mock up everything first, just to get the orientation of the hydroboost unit correct then mark the position of everything. Put the engine in place, then refit and double check your clearance around the valve cover. You will have to relocate the two rear most coil packs if you havent already. Some guys have moved them to the frame rail, the shop that installed my engine had the good idea of mounting them higher up on the coil mounting bracket, just barely enough space to clear but it works.
If your satisfied with the fit, make your final alignment marks for everything then pull it back out to tighten the unit to your mounting plate. The really fun part is tightening that giant nut on the back. Someone on here had bought the proper socket which makes that job easy, we used the big ass wrench method. After my friends shop installed the engine they installed the hydroboost using the alignment marks i made. I am using the Ford master still, but it will be the same with the Porsche one.
Remember to thread the pushrod on the Ford hydroboost for the Porsche clevis. This was also a pain in the butt.
Some pictures from when i installed mine can be seen here..
http://944hybrids.forumotion.com/t1680p75-techno-duck-s-ls1-conversion
Post  Rich L. on Mon Feb 08, 2016 8:49 pm
The thing I've never liked with this installation is the clevis. But cutting off one of the sides, you're putting that bolt into single shear, instead of double. That's not a good idea with something as crucial as the brake pedal.
/soapbox...
Post  Techno Duck on Mon Feb 08, 2016 10:17 pm
I found it was not necessary to modify the clevis as Eric had pointed out, i guess it has to do with where your mounting bracket centers the hydroboost. I was able to attach it onto the pedal normally.
You can see it on the right in this picture;
Post  P911P951 on Tue Feb 09, 2016 6:35 am
I used a heim joint in place of the clevis. Write up here:
http://944hybrids.forumotion.com/t2465-hydroboost-clevis-alternative
Working perfectly so far after 4 track weekends. Brake feel is great with no other modifications needed.
Jack
P911P951
Post  hutchjc1 on Wed Feb 10, 2016 8:10 am
Either you guys are much more flexible and/or you are not as "fluffy" as I am, just trying to get the bolts through the firewall to mount the plate is a killer ! I assume taking out the driver seat will help so I will do that next. Can you remove you drivers side valve cover with the booster installed ? Looks like the PCV valve will be close too but that may change when it is all bolted down.
hutchjc1
Post  P911P951 on Wed Feb 10, 2016 8:51 am
I am fluffy as well but car is track only and completely stripped. Those pics were taken during a trail fit with no motor and access where the HVAC use to sit! As far as valve cover, I have an LS2 and I could take the cover off since they are shallow and no pvc. Changing the rear most plug will be an issue on that side down the road. I expect I will drill a hole in the wheel well for access at some point. Headers, hydro, brake hard lines in the way from top or up from bottom.
P911P951
Post  Lemming on Wed Feb 10, 2016 2:27 pm
Techno Duck wrote:The really fun part is tightening that giant nut on the back. Someone on here had bought the proper socket which makes that job easy, we used the big ass wrench method.
I found one on Ebay, it was worth the $50, but you could easily make one as well.  I sold mine to someone on this forum after I dumped my HB.
Post  BeaverDeceiver on Fri Feb 19, 2016 1:41 pm
I just got my Hydro boost from TPC and am trying to figure it all out. I would love if someone would post a pick the shows which lines go where from hydro boost to the power steering pump. One thing I did to eliminate some of the pain in the ass factor of having to put the bolts for the mounting plate through the firewall and tighten the nuts, while cramming my fat ass on my back in the footwell, I drilled out the bolt holes and installed nutzerts in the holes so I can just put a bolt in from the engine bay and call it good. I wish zee Germans had thought of that. Very Happy
BeaverDeceiver
BeaverDeceiver
Post  gdopnt on Fri Feb 19, 2016 9:39 pm
This is what you are looking for put the cooler before the reservoir after the tee. hydra tech braking is a good source for fittings, including the banjo to an6 for the rack. Verify the correct high and low on Porsche rack the pic shows ford I believe.
gdopnt
Post  zeusrotty on Sun Feb 21, 2016 11:34 am
BeaverDeceiver wrote:I just got my Hydro boost from TPC and am trying to figure it all out. I would love if someone would post a pick the shows which lines go where from hydro boost to the power steering pump. One thing I did to eliminate some of the pain in the ass factor of having to put the bolts for the mounting plate through the firewall and tighten the nuts, while cramming my fat ass on my back in the footwell, I drilled out the bolt holes and installed nutzerts in the holes so I can just put a bolt in from the engine bay and call it good. I wish zee Germans had thought of that. Very Happy
While I like the idea of the nut zerts I'd probably do studs. I trimmed my booster plate to make it easier to remove the heads without dropping the motor. . The lower left corner would always get hung up on the very top of the head.
What kind of which nut zerts did you use? The more I think about it the more I like the idea. Lol
Can you get pics?
zeusrotty
Post  FrostedFlakeJake on Mon Feb 22, 2016 7:53 am
Does everyone's LS power steering reservoir have two outlets like the one in the photo? Mine has one low pressure outlet and the reservoir attached directly to the pump.
FrostedFlakeJake
Post  phlip on Mon Feb 22, 2016 12:55 pm
Thats a Ford resevoir in that pic. Most GM pumps have resevoir attached to pump so you will have 1 high pressure out on your pump and one low pressure in at resevoir.
If you are using the turn one pump which outlet restrictor are you using?
I started with a .140 restrictor and my steering is too light and brakes feel over boosted.
I have a .093 restrictor but have not installed it yet.
phlip
phlip
Post  gdopnt on Mon Feb 22, 2016 8:41 pm
I bought a new one from hydra tech and he advised me to drill a 1/8 hole through mine. if your talking about the valve on the side of the pump. My brakes are very good , the power steering is just a little too easy.
gdopnt
Post  hutchjc1 on Tue Feb 23, 2016 6:13 am
Is this a restrictor that is in place if you buy a pump from turn one for this application or is it something that still needs to be adjusted ? I assumed that their pump for the conversion was ready to go, is that not the case ?
hutchjc1
Post  phlip on Tue Feb 23, 2016 8:23 am
I chose to run the turn one pump because of recomendations on these forums.
It was more expensive then a new stock pump but since I was running both hydraboost and
power steering I thought it was a good idea. The restrictor is built into the outlet fitting.
The pump works perfectly, no noise, I just think when I ordered they asked what size i wanted I asked for thier reccomendation as I wasn"t sure. The result was steering too light, and brakes that are touchy.
I purchased a smaller restrictor and was told that if the result was not enough power assist to
drill the restrictor .010" at a time till the desired power assist was reached.
The pump from turn One is conversion ready, I just think since its used on many different applications
and actual pressure needed was a bit of an unknown and when I ordered I got too large of a restrictor.
When I find time to swap restrictors I will post results.
phlip
phlip
Post  hutchjc1 on Tue Feb 23, 2016 8:27 am
I had ordered mine through TPC so I assume they (Kent) knew what was needed from experience, so I think I may be good to go but will keep this in mind as it sounds like a way to fine tune it if needed.
Thanks for the replies,
Jim
hutchjc1
Post  FrostedFlakeJake on Fri Mar 04, 2016 11:07 am
How much work was it for those who were running the mustang MC to switch to the 944 MC and the adapter?
4-6 weeks from Kent for the next run of 944MC to mustang hydroboost adapters and I was hoping to get started before then. I have the mustang hydroboost with mustang MC in my garage, but not installed yet.
FrostedFlakeJake
