Today at 6:37 am by Patb
» 5.3 conversion on 88 Turbo
» Clutch Issues - HELP!!!
» Hydroboost Lines from TPC
» 1984 Gen IV 5.3 Swap
» Dry Sump Oil Pan Fitment
May 2018
78910111213
14151617181920
21222324252627
28293031
O2 sensor bung location
Post  endrnet on Sun Oct 18, 2009 9:09 pm
Where are you guys welding in the bung for the front O2 sensors?
From working on my other cars and from what I've seen, they are either right on the exhaust manifold or sometimes the just past it on the downpipe.
I'm tempted to weld it into the first section beyond the headers on the downpipe. Putting it further up would seem to either 1) interfere with various flanges or bolt areas, or 2) If put in the collector it would tend to get more of a reading from the nearest cyl rather than the overall side of the motor.
endrnet
Re: O2 sensor bung location
Post  Porch on Sun Oct 18, 2009 11:48 pm
Mine are both near the caster blocks on the a-arms. My advice would be to build the exhaust system first (if you haven't already), then get them as close to the headers as possible on the exhaust. Too far back and they won't stay warm enough to get a good reading!
Post  RobotMachines on Mon Oct 19, 2009 3:16 pm
I welded mine in just after the collectors.
RobotMachines
Post  endrnet on Mon Oct 19, 2009 4:43 pm
RobotMachines wrote:I welded mine in just after the collectors.
Makes sense. Exactly where I was planning to put it -- as far up as I can without getting too close to "stuff". I'll have to see where it'll remain servicable once it's together...
If I'm gonna build my own car, I ain't gonna put stuff where I can't get a dang wrench, if I can help it. Although the C5 BH bolts on drivers side are gonna be a pita.
endrnet
Post  Porch on Tue Oct 20, 2009 10:00 am
Oh yeah, you'd better believe they are!!
