Best bang for the Buck!!!
So quick question, what motor should I go with to keep the price down? 5.3L with LSx intake and assorted parts, or just go with an LS1? I will be ordering the Deluxe kit from TPC and just don't want to spend a ton on a motor to get it to fit right. Goal HP of 300-350 same with TQ numbers. Thanks for any help you all may give.
944james- Posts : 3
Re: Best bang for the Buck!!!
LS1's have gotten really expensive the past year or two; i would go 5.3L personally.
Techno Duck- Posts : 447
That's what I am seeing too. Just not sure how much I would have to put into a 5.3 to make it fit with all the accessory's and intake.
944james- Posts : 3
try tracking down the needed parts and pricing it both ways before you buy, often you can end up spending the same on a 5.3l as you would an ls1/6.
This actually tends to be pretty accurate, based on what I've seen in other builds.sharkey wrote:try tracking down the needed parts and pricing it both ways before you buy, often you can end up spending the same on a 5.3l as you would an ls1/6.
Personally, I've opted for an L33 5.3 largely because of availability in my area. The engine was about $1,600 to my door, after picking it up from a friends shop. I am lucky in that it was a full drop-out, so at that price I managed all accessories (which will probably all need to be changed), the harness and ECU, and the DBW pedal and controller.
On top of that I've still needed to buy a full OE clutch kit to get a flywheel & a pressure plate to start out with - so another $200. Then there will be the water pump and other front-end bits, plus the intake stuff. After all of that, starting with an LS1 would not be all that far from what I will have spent. Although that does depend a bit on your local market.
If I had been planning to rebuild before putting the engine into the car, I definitely would have started with an LS1 block. At that point the price difference would have been negligible.
erioshi- Posts : 227
New to the forum
Just got a LM7 5.3. Going to stuff it into a 1988 944 NA. Blew the head gasket and cheapest rebuild around (in Seattle) was $11,200 so gave me an excuse to go this way.
Any advice would be greatly appreciated.
Thank you
Thank you
Buddy2147- Posts : 10
