Today at 6:55 am by AMFCSL
Today at 1:14 am by sharkey
Yesterday at 9:31 am by Rothaus
Yesterday at 8:55 am by murrayg
» Headers, headers, HEADERS!
» Electric brakes
oil filter and coolant line connection questions
Post  hutchjc1 on Mon Feb 01, 2016 6:56 am
I have the TPC oil pan with the filter adapter in place what filter are you guys using ? I bought the LS1 replacement filter and it does not fit, I wrongly assumed it would use the stock part....
Also when using the stock Porsche coolant tank I assume you would plumb the lower 5/8 connection to the radiator, what do you do with the upper 5/8 outlet / inlet ?
Once again I thank you for any help !
Jim
hutchjc1
Re: oil filter and coolant line connection questions
Post  Rich L. on Mon Feb 01, 2016 12:18 pm
Is this a turbo coolant tank? I have a n/a, it only has one small connection that I t'ed into radiator steam vent and engine steam vent. If your tank has two, you can use one for each.
Not sure on the oil filter, my pan has AN-10 connections for an external filter.
Post  hutchjc1 on Mon Feb 01, 2016 12:31 pm
Sorry I assumed they were the same for the coolant tank, it is a turbo  so there are 2, 5/8 inch ports I used the lower port to go to the radiator as I think it would work fine as an expansion tank, just not sure if I should plug the upper port or if it should be plumbed somewhere else, it has a dedicated port for the steam system with an AN-4 fitting. I know the for sure way to get the filter size is to call TPC but have not been able to get in in touch with any one there.
Jim
hutchjc1
Post  Techno Duck on Mon Feb 01, 2016 6:38 pm
I capped the upper port on the turbo expansion tank.
Post  lsporsche on Tue Feb 02, 2016 8:39 am
Search bud. You're gonna have lots of questions and a lot of them will already be covered by people who went through the same problems.
lsporsche
Post  hutchjc1 on Tue Feb 02, 2016 8:42 am
I did actually find that post this morning and ordered a filter, thanks for the help guys !
hutchjc1
