High horsepower clutch options for the Lt1
I drove the car around a little bit and had to pull the motor back out to address some issues and the pressure plate had some hot spots. I do not believe this clutch will hold up to the abuse its about to receive so I am looking for a new clutch ahead of time. I have the RH bell housing and I believe the largest I can run is a 10.5" clutch. What are some of the option available for the LT1. Also I have the pressure plate that RH sold as their "upgraded" clutch. Any idea what it is? Other than being yellow it has no identification marks on it.
whty8911- Posts : 33
