Today at 9:22 am by robschwieb
» Fix for slow steering
Today at 9:09 am by robstah
» Handling compared to a C5
Today at 8:28 am by haroldk
» 944 LSD turbo/NA transaxle
Wed Oct 17, 2018 7:40 pm by x.l.r.8
» 944 with GM 5.3 / 4l60e / ford 8.8 rear end combo
Wed Oct 17, 2018 2:33 pm by Brownmaxr
» HOW TO DO AN ADVANCED SEARCH.
Sun Oct 14, 2018 10:26 pm by Guitmn
» light delete badge panel.
Sun Oct 14, 2018 8:58 pm by x.l.r.8
» Early / late suspension
Sat Oct 13, 2018 5:52 am by Guitmn
» Used Throw Out bearing
Fri Oct 12, 2018 9:18 pm by Admin
» Used C5 Adapter Plate for 2 piece bellhousing
Fri Oct 12, 2018 9:08 pm by Admin
October 2018
Sparco EVO III fitment
Post  jpkinerk on Wed Jan 06, 2016 9:29 pm
So I recently purchased a pair of "new" (installed once by a tuner whose client changed their mind) Sparco Evo III seats for $900 shipped. The deal was so good I just went ahead and got them. Through my research, however, I couldn't get a clear idea of if these actually fit in the 944 or not. The closest answer I found was that with Brey-Krause side mounts and Sparco sliders, they would fit.
Anyone know if this is true, or should I be looking to flip these?
Thanks, JP
jpkinerk
Re: Sparco EVO III fitment
Post  docwyte on Thu Jan 07, 2016 7:56 am
I've never tried those. I've had Cobra Suzuka GT's, Sparco Evo 2+'s and currently Recaro SPG XL's, all with recaro sliders and Recaro side plates.
Post  Rich L. on Sat Jan 09, 2016 3:22 pm
I have OMP seats in mine but used Sparco sliders and side plates to mount them. A bit of mix 'n match, had to drill a couple holes, but it worked and is solid. I also have a set of Recaro SRD bottom-mount, tilting seats with Recaro sliders that are a much cleaner direct fit.
The SRDs are way more comfortable than the fixed-back OMPs. But they do give up some chassis feel and probably aren't as safe in a wreck.
