Fuel Pump recommendation
+2
wanczykj
6 posters
Tuner is telling me the car is running rich towards the top end and needs a bigger flowing fuel pump than the stock Porsche pump.
Anyone using anything other than the Porsche stock fuel pump?
Tuner is recommending a Walbro 255.
wanczykj- Posts : 41
Re: Fuel Pump recommendation
The Walbro 255 flows more than stock and the Bosch 044 even more. Both are understood to be good, reliable pumps. I still run the stock 944 pump with my 400hp LS1.
By the way, low fuel pressure usually causes lean conditions, not rich. Have you tried replacing the fuel filter, that can cause lean running too.
Thanks for the response Rich.
The car is running lean on the top end. Sorry for the typo.
I was thinking the same thing and already have a new fuel filter on the way. Everything I read says the Porsche pump is more than enough to run the LS1.
I'm running the direct fitment Bosch pump. Believe it's from a '70's Benz, it's the one Lindsey Racing sells
ive got an aem 380lph pump on my car. its the same dimensions as the bosche 044 pump.
I'm running the walbro 255, have been since I built my car. At close to $100 a pop, I keep a spare with me, although I've not needed it.
Thanks for all the info. Ended up going with the AEM 380LPH. I will let you know how it worked out.
I have finally gotten around to mounting the pump, and I am happy with the purchase so far. Pump can't be heard while the car is running, and the fuel rail stays a steady 58psi at all throttle positions.
Thanks for the advice from all.
Nice to know the AEM is quiet. I have a Walbro 255 providing fuel on my '79 928 right now and it's noisy. I've been considering looking for a better solution, but figured it would work to get me up and running, and I could replace it later.wanczykj wrote:I have finally gotten around to mounting the pump, and I am happy with the purchase so far. Pump can't be heard while the car is running, and the fuel rail stays a steady 58psi at all throttle positions.
erioshi- Posts : 227
