RHD Conversion Issues...
Hi all,
has anyone used the TPC conversion parts on a RHD (UK/Oz/NZ/etc) car and had any issues with fitment, i.e does the steering rod linkage clear the headers etc... ?
Cheers,
KW
Cheers,
KW
Korenwolf- Posts : 17
Re: RHD Conversion Issues...
Hi mate, aussie here.
Ls1 into an 88 951. The cast iron exhaust manifolds will def foul on the steering shaft.
I have a set of VY Commodore manifolds, and the steering shaft nearly perfectly bisects the outlet on the drivers side (RHD).
Im looking for a set of tight block huggers that will work for the time being.
XtaC- Posts : 9
Is that the only issue so far? was just looking at the TPC delux kit (again)
I have been really busy with work since I first planned this but hoping to have more time to get started this year. I amassed a few more new general parts in the mean time for the car saratoga roof / kw suspension etc. (Car already has Big blacks and other mods).
If it is just the manifolds - which should be possible to get adapted or built to suit locally I will get the kit ordered! I am planning LS3 crate motor, rebuilt box and torque tube and want to keep it reliable and long lasting. previously had c 350hp as modified turbo and it became fragile. Unstressed 400bhp (+) will be perfect
Tony
Tony
UK952- Posts : 25
To be honest, my 86 Turbo has changed into a restoration project, esp given the upwards price trend over the last few years...
That still leaves me an 88 shell I can't register on the road in NZ as a factory car due to a dumb law, however, if I remove >60 % of the chassis rails and replace with a tube frame then I can register it as scratch built. So, I've acquired the front and rear subframe units from an early cayenne, a toyota v12, a tremec 6 speed out of a commodore and will cut the front off, bottom and rear out and replace with a complete space frame mounting the subframes.. sort of mad maxish
Sounds like an awesome project! (nd just spotted the date on your original post!
UK952- Posts : 25
