» New 944 widebody & aero
Yesterday at 6:20 pm by scryfst
» ecotec swap
Yesterday at 6:16 pm by sharkey
» Wilwood MC on it's side
Yesterday at 6:09 pm by scryfst
» V8 Conversion Parts
» Fuel pump options
» Poly engine mounts melted
» JP's LS1 Conversion
March 2018
steering shaft question
Post  hutchjc1 on Tue Dec 08, 2015 12:00 pm
I have seen mention of maintaining the clocking of the steering shaft while adding the length for the spacers, on the car I bought the PO had started to lengthen the shaft but started out by cutting it. I have no way to tell where it should be clocked from on end to the other, does anyone have info on this subject that they could share ? With a splined shaft does it really matter, the only thing I think it would get you is access to the bolts with out having to turn the wheels, is there more to it ? It is a 1986 turbo if that matters......
Thanks for any help,
Re: steering shaft question
Post  murrayg on Tue Dec 08, 2015 2:28 pm
ya, there is more to it than that.  If it's not "clocked" properly, it'll bind and jam up.  The u-joints have to be indexed from each other.  just use a original one as a reference.
